Date: 08/13/2018 02:46 pm
Date: 02/25/2017 08:45 pm
Misc pinto parts 71-73 2.0
Date: 05/05/2020 11:56 pm
A.c. alternator hrackets
Date: 09/03/2017 12:11 pm
Date: 02/22/2017 01:58 pm
Date: 08/27/2018 11:11 am
1978 Squire wagon 6 Cly
Date: 03/08/2021 10:44 am
1976 Pinto runabout
Date: 03/28/2017 08:14 pm
1972 Rallye wagon rebuild
Date: 11/14/2020 07:31 pm
  • Online today: 1,166
  • Guests: 523
  • Total: 523
1980 fuel pump
Started by sedandelivery, August 06, 2015, 10:06:46 AM
sedandelivery
I went the electric pump way, so let's see if that works out. I am taking offers on the car as I have 2 now and only room for one Pinto as I have 5 other cars here. Thank you for the reply.
That's odd never seen one wear out but easy to change , do not know if you can do the work your self or have to get someone else to do it , you have to remove the timing cover and belt to get to the shaft , you remove the distributor, fuel pump and then the timing belt sprocket, the the three little bolts , remove the cover and you see a plate with two screws , remove them and shaft will come out , not hard at all, but first I would make sure the lobe is really gone before you do this for nothing, remove pump and use a smart phone and take a few photos and post , turn the engine to see all sides of the lobe , and last is make sure the timing belt is good , they ether brake in half or sheer the rubber teeth off on the crank sprocket, then the engine will not run , no fuel pump, distributor or oil pump , all driven by that shaft , good luck , later Blaine
sedandelivery
On the bench the old pump pumps well, the new one has a much stronger spring and pumps better. He says he put his finger in the hole and the lobe is gone.
that is very strange to hear a lobe to wear out . make sure he has the right fuel pump, most fords take the same fuel pump gasket and you can bolt the wrong pump to the engine , (lobe is in a different spot)  or you might have a bad new pump,  pull it off and match the old one that use to work to make sure , the arm has to have the same shape as the old one , if not it came off a different engine , hope this helps
sedandelivery
My Pinto was not getting gas to the carb, and a mechanic put a new pump on and said the lobe that works the pump is worn out. What electric pump would work to bypass the mechanical pump? Or is there another fix?
