78 pinto wagon
Date: 06/04/2020 12:42 pm
78 hatchback
Date: 03/12/2023 06:50 pm
Wanted hood hinges
Date: 02/17/2020 05:30 pm
Clutch Cable Needed
Date: 04/03/2017 10:54 pm
Date: 07/08/2022 11:51 pm
Date: 02/28/2018 09:18 am
1971-1975 Pinto
Date: 01/09/2017 04:14 pm
1977 Pinto Cruizin Wagon
Date: 04/11/2024 03:56 pm
  • Online today: 1,166
  • Guests: 450
  • Total: 450
Windshield weather strip needed
Started by Tonycando, July 27, 2015, 09:29:39 PM
You didn't state which year car you have. The latter year Pinto's had a glue in windshield. I looked at my '73 windshield and the trim is a separate item from the windshield seal. Meaning it isn't in-bedded in the rubber as some cars have.  My seal itself is all black rubber and the metal trim is attached by clips and welded pins on the windshield frame. Thus, the trim lays over, but does not attach to the weather seal itself.  So, I would assume if you, " ...don't want no trim around the windshields" that you can just forgo it but at least on the early cars the pins will show unless you grind them out.
JoeBob
I got one from green sales two weeks ago for $79.00
77 yellow Bobcat hatchback
Deuteronomy 7:9
Tonycando
Quote from: Reeves1 on July 29, 2015, 05:42:04 AM
Another place to try: http://www.steelerubber.com/search?year=1972&make=ford&model=pinto
I emailed them and no luck,I got a reply today from Kanters and they can get the front and are looking into getting the rear.
Thanks for the tip
Tonycando
Has anyone seen where or if a weather strip is available for the front and back glass that does not require the trim,I really don't want no trim around the windshields.
Thanks all
Tony
