1980 Ford Pinto For Sale
Date: 07/01/2018 03:21 pm
Date: 10/03/2018 10:46 pm
Looking for a few parts - TIA
Date: 02/19/2023 12:18 pm
Date: 09/01/2017 07:52 am
Date: 12/20/2016 10:47 pm
Parts for 74 Squire Wagon
Date: 09/16/2019 07:35 pm
1978 RUNABOUT
Date: 04/01/2017 03:18 pm
Date: 10/24/2019 01:43 pm
1980 pinto/bobcat floors
Date: 07/24/2018 08:11 pm
  • Online today: 1,166
  • Guests: 515
  • Total: 515
Engine swap headers
Started by Pintocrazed, June 13, 2015, 05:31:50 PM
Hooker used to have 2 separate part numbers for 302 headers. One fit 71-73 & the other set was 74-up so my instincts say there are differences.
Since all I've worked on over the years are 1972 cars, I cannot say they'll for sure fit newer cars.
From all I've read though, the newer ones are wider : so they should fit.
If I were you, I'd buy them. If they do not work, sell them.
BTW - I paid much more for a couple sets. Likely have between 500 - 600 into each of them.
The ones you looking at the Hookers ? The ones that the back 2 tubes go through the inner fenders ? May need to mod them if so, depending on when made ?
Both my sets are the Headman flat collector type. No cutting to install.
Pintocrazed
dead pony racing
from looking at the pictures of them you might have to really check out the crossmember location and the rack and pinion these headers also have a smaller 2 1/2" collector
Pintocrazed
Sorry shoulda put that.supposed to get another pinto which they'll be used on but it's a newer pinto
Must be missing something.....you want to buy V8 swap headers & not use them ?
Pintocrazed
Will 71 to 73 v8 engine swap headers fit the later models?got a chance to get a used set for 230.and don't want to put a v8 in my 73
