Date: 03/06/2017 01:19 am
Date: 04/08/2018 05:47 pm
72 pinto drag car
Date: 07/08/2017 08:53 pm
SEARCHING HOPELESSLY
Date: 02/02/2017 07:21 am
1980 Pinto Parts
Date: 08/05/2020 04:20 pm
1974 Ford Pinto Squire Wagon
Date: 05/30/2020 01:51 pm
Date: 01/19/2020 09:06 am
Date: 12/30/2022 01:30 pm
WANTED Hood Prop Rod
Date: 01/17/2017 02:47 pm
  • Online today: 3,109
  • Online ever: 3,109 (Today at 06:23:23 AM)
  • Guests: 2236
  • Total: 2236
FUEL PUMPS??
Started by Trucker Tim, June 04, 2015, 06:59:38 AM
Quote from: 72pair on June 07, 2015, 09:15:17 PM
Yep, glad to hear problem solved. Learned something new too. In 30+ years of pintoing I had never seen a ranger style fuel pump. Putting that in the memory bank!
I learn something new everyday, gotta love it.. :D
72pair
Glad to hear it works.. 8)
Trucker Tim
Pump installed! Worked great. Photos on the "Pinto engine In 1948 Willys Jeep" thread.
"All that is necessary for the triumph of evil
is that good men do nothing."
Trucker Tim
I want to thank all of you for your input!
Going to check and see if I have room in the Willys engine compartment for the mechanical pump. Might try and followup with a few pictures. I am told the pump from a Ranger might fit if I have a tight fit with the front drive shaft. Going to measure tomorrow am.
HOSS429
the only reason to run an electric for anything near stock is because you cant run a manual .. my V6 in my pinto can not run a manual .. i`ve had an electric since the day i built it 11 years ago .. not a moments problem ...
Good new, not rebuilt mechanical pump can't be beat. I try to find older NOS ones on ebay to avoid Chinese junk at Autozone. If you travel it's a good idea to have an electric with a few feet of hose & some wire in the toolbox to get you going if the pump ever quits.
78_starsky
Running a Mr,Gasket electric in my build, located 1 foot from the tank with no probs. 2.8 engine.  However, i did wire in a inertia switch into the wiring loop. Took it from a ford ranger that i had parted out, plus i wired in a kill switch under the dash for second measure.   so far all is working good.
cheers
Can't beat a good mechanical for reliability and safety IMO, electrical is good for priming though but I just use a squirt bottle.. Guess I'm just paranoid after an electrical left me stranded in the middle of nowhere, lol..
72pair
Mechanical pumps for the 2.3 are inexpensive, usually pretty reliable, and will stop pumping if the engine dies. The plus side to an electric pump is you can instantly prime an engine that's been sitting awhile...less cranking. My $0.02
Trucker Tim
Hey Crew.
  Long time no see. What are your thoughts about the preferences between a mechanical fuel pump vs. an electric one?
