Date: 01/20/2018 07:51 pm
78 wagon instrument y
Date: 04/30/2018 07:41 pm
Pinto 4-spd transmissions
Date: 06/15/2018 09:15 am
Need Brakes for 1971 Pinto
Date: 04/27/2018 11:48 pm
1971 Pinto Parting out
Date: 07/06/2018 01:11 pm
Date: 09/15/2019 12:28 pm
front end parts
Date: 03/30/2018 12:48 pm
Date: 07/17/2018 09:22 pm
71-73 Front Kick Panels
Date: 04/25/2021 07:24 pm
  • Online today: 1,106
  • Guests: 100
  • Total: 100
Front under bumper air dam alternative.
Started by High_Horse, July 26, 2005, 10:35:35 AM
I had a little time so I thought I would pop off some pictures of this thing while it was off the car. The picture below is the spoiler flipped upside down with the 77 grill right side up in front of it.
I mentioned in the " Projects" area that I am using the front air dam off a Buick regal on my 77 Pinto. I need to make a correction on that statement. It is not a Buick Regal but a 88-89 Chevy Celebrity. I happened to see this dam on a car that my friend was towing off and asked to have it. I found that the louver was an excellant match to the stock grill on my Pinto. The front width was good for a fitup right to the underside of the bumper with the fabrication of some small brackets. The only thing that I had to cut was the wrap arounds. They needed to be a little shorter. Then the back of the wrap arounds screwed right into the front/lower wheel wells. There is a space that could be filled on the front side body but I never did. Also there is about a 1/2 inch flat that runs along the bottom of this spoiler which enabled me to  screw a 2 inch piece of sheet metal to to extend the dam downward. I have had mine on there since 92. I will post better pics of this down the road a bit. Mine is off right now cause I am doing the radiator thing.
