Date: 02/18/2017 04:47 pm
Date: 06/25/2021 12:59 am
turbo 4 cyl and aod trans
Date: 12/14/2019 04:55 pm
Rear brake shoes
Date: 01/23/2017 05:01 pm
Hoard of Pinto parts
Date: 12/17/2016 04:14 pm
Date: 05/28/2017 03:20 pm
75 wagon need parts
Date: 05/28/2020 05:19 pm
1972 Pinto for sale
Date: 05/19/2021 12:41 am
Date: 04/12/2017 08:15 am
  • Online today: 367
  • Guests: 264
  • Total: 264
rear end up-grade
Started by 74PNUT, July 25, 2005, 07:28:36 PM
Hello 74 P-NUT,
The rear that you describe will bolt right in with the U-bolts BUT You will need a different rear U-joint.
Maybe that is only for the pre-74 models???? Because the part numbers are the same for a 74 and a 77 Pinto.
The rubber brake line that supplys the brake fluid to the rear wheel cylinders will also be a small problem.
Maybe the one from the wagon will work.
BE SURE NOT TO CUT THAT RUBBER LINE!!!!
I may be possible that it is no longer availble.
The wagner part number  for the rear hose.
WAGNER F80014 2.3 rear brake hose
WAGNER F80024 V6 rear brake hose
AC DELCO 45U0107 U JOINT 2.3
Note: at trans
AC DELCO 45U0129 U JOINT 2.3
Note: at rear axle
Hope that helps you out some???
The axle should be a bolt in to your 74.
74PNUT
i have access to a 77 wagon parts car to have any parts i need.it has a v6 and BIG rear end.will it work under my 74 sedan without too many mods.?????     thanks,  74P-NUT
