72 Pinto
Date: 03/07/2019 12:07 pm
Various Pinto stuff for sale.
Date: 11/21/2018 01:56 pm
Date: 06/18/2018 03:47 pm
SVO SWAP
Date: 03/15/2018 03:12 am
Date: 08/09/2018 11:09 am
Date: 10/03/2018 10:46 pm
1978 ford pinto carb
Date: 02/04/2018 06:09 pm
Date: 07/30/2018 04:32 pm
Date: 09/26/2019 05:31 pm
  • Online today: 642
  • Guests: 606
  • Total: 606
Wiring harness unplug ?
Started by Tonycando, April 26, 2015, 11:41:38 AM
Bolt through the center, then two squeeze tabs : use care, they can break easily !
The bracket that holds this can be un-bolted & lowered so it's easier to see.
Tonycando
Quote from: amc49 on April 26, 2015, 02:14:12 PM
If talking the main firewall crossover point IIRC there a couple screws may have held the two halves together.
Yes it goes through the fire wall and plugs in under the dash
Tonycando
Is there a trick or are they just old a stubborn,the harness under the hood has been played with to much and I'm planning on useing the harness from my parts car.
Seems simple enough but where it plugs in under the dash it will not come apart,any tips or secrets will be appreciated.
Thanks
Tony
