Date: 01/12/2019 10:19 am
Date: 01/10/2022 03:41 pm
1977 Pinto for parts
Date: 10/10/2018 06:25 pm
ENGINE COMPLETE 1971 PINTO
Date: 12/28/2017 03:55 pm
Date: 06/22/2017 07:19 am
Date: 09/10/2018 10:41 pm
Date: 03/27/2017 10:07 pm
1600 CC WATER PUMP
Date: 06/02/2018 09:13 am
Date: 08/01/2023 06:53 pm
  • Online today: 656
  • Guests: 589
  • Total: 589
Front end weight with a V8 ??
Started by Tonycando, April 09, 2015, 12:59:40 PM
fozzy
1971 sedan. 289 with alluminum heads and a C-4 auto
weights with passenger and driver
Total 1280kg.  2821lbs
700kg front. 1543lbs
580kg rear.  1278lbs
rpaulsel
I have a 76 wagon with v8, 4 speed, and 8" rear from an MII.  Engine is set back enough that radiator is still behind the support.  Front is 1560, rear is 1380 lbs.  (53/47)  Hope this helps.
Roger
76 Pinto 302 wagon
Also depends on motor and heads. Cause a LS1 weighs  pretty close to what a turboed 2.3 weighs so springs could be a lot closer to stock were as a big block is gonna weigh a ton more.
Tonycando
When I first got my car (302w & T-5) I went to the self scales east of town.
Weighed the front, then whole car, then back.
Wrote it all down........and have not seen the note since !
So, I'm no help  ;D
79prostreet
Tony, I moved my motor back 4'' and I'm @ 1600 on front & 1400 rear. I would think 1700 should be real close. Bud
79prostreet
Tonycando
Has anyone checked what the weight was on the front with a V8 swaped in,I am looking into a QA1 coil over shock for my 71 and and they are guessing a 16 to 1700 pound weight and a 600 lb spring, are they pretty close with their guess or what are your thoughts on this.
Thanks all
Tony
