Date: 09/01/2017 07:52 am
1977 Left Side quarter panel
Date: 06/10/2019 04:16 pm
1974 Ford Pinto Runabout
Date: 07/10/2025 09:33 pm
Squire trim
Date: 03/28/2018 10:11 am
2.3 bellhousing stick
Date: 07/24/2019 06:50 pm
Date: 03/05/2017 03:27 pm
Date: 02/18/2017 05:55 pm
Date: 11/05/2020 06:32 pm
Date: 08/24/2018 02:50 pm
  • Total Topics: 16,268
  • Online today: 289
  • Guests: 153
  • Total: 153
Roadrace Squire, will a 1.6L 4 speed trans bolt up to a Zetec?
Started by Sir Thomas Crapper, March 19, 2015, 07:39:24 AM
How to mount the zetec? They have no side motor mount pads at all, they mount on front cam belt cover.
  • [size=78%]From what I remember ,back then the Kent engine (1600 pinto) had the same bolt patern as the 2000 pinto German engine, then the later 2.3 Lima engine , only the alignment dowels were larger, the later 2.3 bell housings got taller and used the upper two bolt holes on the block, they all took the same size pilot bearing, [/size]
  • [/size]
enzo
I found this info while researching a V6 project.  I don't know if the "EAO" is the kent motor.
Ford Pinto EAO I4 pattern
·   1.6L/2.0L EAO I4
Ford Canadian Essex FWD pattern
·   2.3/2.5L HSC FWD I4
·   2.3L HSO FWD I4
·   3.0L Vulcan V6 (FWD and RWD)
·   3.0/3.2L SHO V6
·   3.8/3.9/4.2L Canadian Essex 90 degree FWD V6
Ford Pinto OHC RWD pattern
·   1.3/1.6/1.8/2.0/2.3/2.5L OHC I4 RWD
72DutchWagon
I think this link will provide some help; http://www.retro-ford.co.uk/shop/content/fitting-zetec-mk-12-escort-type-9-gearbox .
The MK1/2 European Ford Escort is relatively close in design to the Pinto with crossflow engine,  a lot of the problems that you are also going to run into are carefully explained here.
For most problems they have fixes, but you'll see that it all adds up rather quickly.
Sir Thomas Crapper
I'm trying to dig up info, but I remember seeing somewhere that a 1.6L Pinto engine is a "kent" and that a 2.0 Zetec has the kent bell housing bolt pattern.
Long story longer, I have a free Zx2 at my brother's house, and can pick up a cheap 1.6/4 speed.. Free Zetec + cheap 4 speed= WIN???
Please help me make this happen.
