Early Rare Small window hatch
Date: 08/16/2017 08:26 am
1974 Ford Pinto Squire Wagon
Date: 05/30/2020 01:51 pm
SEARCHING HOPELESSLY
Date: 02/02/2017 07:21 am
pintos for sale
Date: 12/11/2018 04:29 pm
Date: 04/30/2023 04:31 pm
Date: 11/12/2020 08:28 pm
Date: 08/30/2021 03:20 pm
1979 hatch needed
Date: 05/13/2018 08:52 pm
Automatic Wagon
Date: 06/14/2019 11:22 pm
  • Online today: 382
  • Guests: 354
  • Total: 354
2.3 mild performance build help
Started by KoepkeZ, March 17, 2015, 09:44:21 PM
 The turbo setup is a bit beyond mild but basically doubles the HP while retaining driveability and mileage (when you keep your foot out of it). Regardless it is probably the best setup for those seeking more power. While some do the V-8 swap it is said to be front end heavy.  Otherwise you are probable looking at  N/A modifications that will net you 10-20 HP maximum. You will have to rely upon others who have done N/A modifications to tell you if they result in any noticeable increase.
  The blow through turbo is not the best setup. Most all would agree to get a donor Turbo Coupe/Merkur/Mustang (turbo) and use the factory injection system. Especially since you have cost considerations .  The good news in your case is that you have a post '73 car and a Bobcat. The 2.3 mounts are already in the car and the Bobcat hood is said to give more clearance.
Here is a turbo swap write up I did. It should give you an idea of what is involved:
http://www.fordpinto.com/index.php?topic=11908.msg76893#msg76893
http://www.fordpinto.com/general-pinto-talk/so-you-want-to-build-a-turbo-pinto-part-2/msg76894/?topicseen#msg76894
76hotrodpinto
Why the blow thru? From what I understand, their harder to find the parts for, fairly troublesome, and don't allow for as much boost as the efi rig.
KoepkeZ
I will more than likely go with the blow through turbo and go that route. But want to start from the ground up and the slap that turbo on for a kick
"If it doesn't run push 'er down the hill"
dianne
Vehicles:
- 1976 Mustang II mini-stock
- 1978 Mustang King Cobra II
- 1979 Ford Pinto Runabout
- 1986 Chevy K5 Blazer
- 1997 Suzuki Marauder
KoepkeZ
I have a 77 bobcat with the 2.3 and wanting more power but not sure of all options for the best outcome. I want to build the original motor but not sure if its worth it or to just drop a 302 into it. Any tips or ideas or anything in detail would be awesome. Overall i want a daily driver but power to play with every so often. Just wanting to know what works best for the build that has the best HP outcome that doesn't deplete my bank account. HELP!!!! thanks
