Date: 03/23/2018 09:23 pm
1978 ford pinto carb
Date: 02/04/2018 06:09 pm
Cruiser Dash Gauges
Date: 12/04/2016 11:50 am
Date: 02/22/2017 01:58 pm
Wheels and Parts
Date: 07/06/2018 04:50 pm
Drip rail chrome
Date: 01/14/2017 09:18 am
1974 Wiring diagram free
Date: 10/27/2019 06:56 pm
Wanted 1973 Ford right fender
Date: 06/03/2017 08:50 pm
1974 Ford Pinto
Date: 10/16/2017 10:45 am
  • Online today: 330
  • Guests: 356
  • Total: 356
v6 question
Started by krazi, February 25, 2015, 07:44:16 PM
ALL rod pairs on vee type engines have a slight amount of front to rear clearance, you just didn't find it in the other pairs. The number can get pretty loose there. Need at least the minimum  number the engine specs specify, too tight and the oil flow is trapped and you can then burn up a rod bearing. The side clearance serves as an oil metering device just like the actual clearance to the journal itself. Why both get loosened up a bit on race engines. With all mismatched pieces when rebuilding you swap out rods to somewhat even out that clearance between all pairs, it does not have to be exact.
krazi
I'm rebuilding a 2.8 for my bobcat, and when I pulled the oil pan, I checked the rod ends for play. on the #6 rod, I noticed front to back movement (thrust), but no side to side movement (knock). didn't pull the cap. the other 5 are in good shape. do I have a serious problem? can I get a few miles out of it as it is? not that important to me.
yeah, I'm Krazi!
