'80 Pinto Wagon
Date: 02/01/2018 05:20 pm
72 pinto and 88 turbo coupe
Date: 06/09/2016 04:13 am
SEARCHING HOPELESSLY
Date: 02/02/2017 07:21 am
Need Interior Panels
Date: 07/09/2018 04:59 pm
Automatic transmission
Date: 02/13/2021 02:52 pm
Wanted - 71-73 Pinto grill
Date: 12/15/2016 03:32 pm
Date: 03/18/2020 01:30 am
Rear brake shoes
Date: 01/23/2017 05:01 pm
Date: 08/26/2018 06:35 pm
  • Total Topics: 16,268
  • Online today: 191
  • Guests: 143
  • Total: 143
Taking the turbo plunge!
76hotrodpinto
I didn't check it for that, just for voltage at closed, with iac unplugged. No difference in the reading, from max to min settings, but big difference in performance. I feel like I'm leaning out under boost though.
Is the +5v TPS power leg supplying a good 5v? Are there any dead spots in the TPS sweep?
There is a KOER "goose test" where you stab the throttle very quickly and the ECU will detect dead spots or a bad signal.
76hotrodpinto
I think I have a funky tps. I see many choices of brands, but some have mounting holes and some have slots. Do the ones with holes still rotate somehow, to adjust? I've also seen a few motorcraft units for big$. Is it something I can get off brand, and still get quality performance?
It still runs pretty well, but the tps tests out in mv's, won't even muster a half volt.
76hotrodpinto
I had to fuel up last night, and I just went to the local gas station. It was nice to be able to get fuel so easily, instead of having to head to the race gas station. And still have more hp to get there! I love this little pinto.
76hotrodpinto
Quote from: dga57 on August 02, 2015, 10:18:20 PM
Yikes!  I'd rather eject out through the top than fall out through the bottom!
Dwayne :o
That's why you grab the dash!
Quote from: 76hotrodpinto on August 02, 2015, 12:23:10 AM
No ejection seat... per say... How about rusty floor pans?
Dwayne :o
76hotrodpinto
Quote from: pinto_one on August 01, 2015, 03:19:18 PM
hope your ejection seat is up and working , just in case  :o
76hotrodpinto
Quote from: pinto_one on August 01, 2015, 09:37:12 AM
To bad your far away , if you were near I would grab my G suit and helmet and take a test flight ,opps I mean a ride with you 🏁
G suit?
Quote from: 76hotrodpinto on August 01, 2015, 12:18:02 AM
I'll see if I can find someone brave enough to hold a camera, and not grab the dash.
;D ;D ;D ;D ;D ;D
76hotrodpinto
Pics video or it didn't happen.  ;)
76hotrodpinto
Got some road under her today! It was all worth it. Happiness!
76hotrodpinto
Aaugh! One stupid radiator hose away from hitting the road! The waiting is killing me(that and the heat!)! It should be here in the morning, and I should be road testing by lunch.
76hotrodpinto
I got my radiator mounts fabbed out.
And got it installed, after finishing core support mods and painting.
Still have the fan and hoses to put in, but it's pretty much done, as far as fabbing stuff goes. Till the next major upheaval... I'm just itching to go drive this thing!
Rebolting73
Congratulations ! Enjoy :-)
Way to go!!!  Congratulations!
76hotrodpinto
IT LIVES!!!
I got her running today! I had to switch the hoses on the fuel pump around, but it fired first time after that. I got the intercooler mounted and the radiator mounts plotted. I have all my parts, and it's gonna be a tight fit for the 12v fan. But it runs now!
Agreed. And, I'll offer this too. Depending on how you plumb the intercooler you may be tempted to rotate the turbo inlet housing. It is easy enough by loosening the screws and turning it. But, it alters the waste-gate puck in relationship to the designed tension. I get full boost, but I think I'm bleeding early on the way up.  Ideally I would desire to have the rod threaded right/left so I can adjust the tension properly.  If in fact you have done this look for marks where it was originally set.
No, the wastegate linkage should not be easy to move. It should move smoothly, but with a lot of spring resistance.
76hotrodpinto
Should I be able to move the boost control linkage by hand... not running? I was checking it for play and realized it doesn't move, not easily anyways, I'm not going to force it. But it seems like I should be able to actuate it by hand, if that vac solenoid can. Am I wrong?
76hotrodpinto
Quote from: Wittsend on July 20, 2015, 10:49:19 AM
It is always enjoyable to see your progress. So often we get people who "talk" this endeavor, but don't always" walk" it. Of late yours and 65SC's turbo projects (my apology if I missed any others) are a testament to the tasks need to complete these types of projects.  To me it is like a fraternity, a brotherhood - especially when we are doing all the work ourselves.  Not that we are any better than anyone else, but that we have "passed through the fire."  May your new parts arrive "SWIFTLY."
Thank you brother! I REALLY appreciate all the help from you and 65sc and pinto-one and pintocrazed, on this(sorry to anyone not mentioned). I feel like I have been passed through the fire too, after working through the heat wave.
76hotrodpinto
I filled the trans and got her down off the jacks today. But that's about it. I did order a 22" aluminum radiator, a 16" fan and a 22" x 12" intercooler with 2.5" ins and outs. Not much left to do till those parts get here. It looks nice on the ground again.
76hotrodpinto
Made a wrecking yard trip this morning and scored a few pieces. Still no radiator yet. I think I'll break down and get a new aluminum one.
Got a 45.5 inch aluminum drive shaft.
And some intercooler tubing. I got a k&n filter put in.
I put the fuel system all together at the pump. Still need to make a filter bracket.
Some small stuff, but it's nice to be at it again.
76hotrodpinto
I put the front end back together to measure for an intercooler and air filter... and possibly a pusher fan. I do like the way it looks now, other than the lump.
76hotrodpinto
Cleaned up the bumper bracketry and sprayed them black.
And cleaned and sprayed the back of the bumper as well. (damn ocd!)
76hotrodpinto
Quote from: Wittsend on July 06, 2015, 09:07:54 AM
That looks a whole lot better with the bumpers retracted.  Should you ever have access to a set of 71-73 bumpers (and desire them) here is a pictorial of a guy who swapped the early bumpers onto a later car http://www.joe-escobar.com/pinto.html. Scroll about a third of the way down.  The hood bulge has a very stealth fighter like look. Maybe it will help evade radar. LOL
You may be struggling with the heat (and working on gravel), but you are making very good progress.  That said, the date of your first post indicates you started over 6 months ago. So, your build I think is a very good indicator of the time it takes to do the turbo build. It sure doesn't happen in a weekend.  We often get guys here who like the concept, but you can generally tell they are rather clueless as to what it really requires. Your posts show the diligence that is necessary. Carry on!
Stealth fighter... I like that! Maybe I'll paint some some little windows on it for kicks. I've had the pinto torn down for about 6 weeks now. And I put between 4-10 hours in on it everyday. Everyday. I stopped for one day, a while ago, and the rigor mortise set in. I'm afraid to stop again.
