Date: 02/25/2017 08:45 pm
Wheel cap
Date: 04/25/2022 11:21 pm
Front sump oil pan
Date: 01/02/2017 06:54 pm
1980 pinto/bobcat floors
Date: 07/24/2018 08:11 pm
Rear Bumper
Date: 07/26/2021 01:08 pm
Date: 10/25/2019 03:30 pm
Clutch pedal needed
Date: 01/11/2024 06:31 am
2.3 turbo intake (lower)
Date: 07/15/2020 09:29 pm
2.8 radiator
Date: 10/25/2019 04:10 pm
  • Online today: 2,773
Taking the turbo plunge!
76hotrodpinto
Look what santa brought me! Just what I've always wanted. A kuup stage 3 clutch kit!
And here it is on the flywheel. Shiny!
76hotrodpinto
I attacked the core support today. It was pretty wrinkled up at the bottom. I chopped off the bottom where the majority of the damage was and replaced it with some square tube.
I should get my new clutch tomorrow too.
76hotrodpinto
Here's a couple pics of my upper intake mounting thingy's.
And here's a big brass nut... one of a pair I have!
76hotrodpinto
Still too hot to work outside on the pinto, but I got some indoor stuff done.
Got the egr tube to come out gracefully, and plugged it.
And I made a delete plate for the intake.
Then I got the intake rotated 90 degrees.
I plan to port match the upper and lower, but I ran out of gumption for the day.
76hotrodpinto
I didn't get as much done today as I had hoped. The heat today was whoopin' my... uhm ... fanny? But I did make some progress.
The shifter hole is done.
And the firewall seam is welded and rough ground, still needs to be flap wheeled a little.
My little clark/tweco hybrid, and the german section.
76hotrodpinto
I got the motor and trans. pulled back out. Now comes the fun part... really building it!
Tomorrow I let the sparks fly. Going to weld up the firewall, and gusset the corners a little. Patch the fender well, and put the access panel in. Put some stitches in here and there, just cause it's a good time to. I'm going to fill all the misc. holes I won't be using and doing some core support mods.
I found that the cowl area seam, covered by the fender, was needing some love too. Going to clean up the whole area then re-caulk and paint while I'm in there.
I still need to go to the yard, but that will have to wait till after our little heat wave passes. Still need my clutch too. I may have to just do the whole ebay thing. Ugh.
76hotrodpinto
I think I finally have the right heater fan motor ordered. I'm still not sure how it turned into an ordeal.
I have about everything I needed to mock up and make holes/bends/alterations done. Next I'll pull her back apart and do all the welding.
Still haven't got my radiator supports replaced, but I haven't found a rad. I want yet.
Is there a resource to reference ford drive shaft data? I need 45.5" to clear the rear yoke and set in place.
I may have to give up on getting a centerforce clutch any time soon as well. Maybe my parts guys are slacking, but they're not finding anything for me. Those spec clutches have some good reviews, but I've never laid into one myself. And they're not on sale either. I have about a week to figure it out.
The suns coming, and I want to go fast!
Keep in mind also that these guys are using engines out of '87-88 Thunderbirds. The upper intake is shorter than those of earlier 2.3T cars (hence the notch in the valve cover). I had a bigger uphill battle fitting an earlier turbo engine in an early Pinto with a 7qt pan. That's why I still haven't sorted out the hood situation.
Quote from: 76hotrodpinto on June 03, 2015, 12:24:00 AM
I can't say that aluminum one doesn't sound spiffy. I'd like to find one, and discover it works. But I won't hold my breath. I've shortened a couple shafts before, but I had access to a jig that was made to hold them straight. I figure I'll check a few aerostars (and others)before I cut mine up. Wish I had my yard list together a couple weeks ago on 50% off day.
You won't find a suitable aluminum drive shaft under an Aerostar unless it's an AWD Aerostar. They weren't common to begin with and many have already been picked by Mustangers thinking they're getting a cheap Ford Motorsport equivalent(it's not). Fortunately just about anything out of a V8/V6 '79-04 Mustang will be about the right length. U-joints could be 1310 or 1330 depending on year and trim level.
Quote from: Wittsend on June 03, 2015, 11:39:57 AM
The only major difference (swap wise) between a 71-73 and a 74 and up are the motor mounts and a reduced clearance at the radiator. An electric pusher fan easily solves the radiator clearance problem.  If you willing to set the engine 1/4"-1/2" higher and use a low profile hood scoop the clearance issues with the engine go away too.  All the other modifications necessary are needed for any year. So, while there are a few more issues with a 71-73 they can be resolved without too much effort.
Thanks and that's good to know. It looks like the EFI engine in the 79 is up too high also.
Quote from: dianne on June 03, 2015, 07:24:34 AM
The more I read, the more I don't know if it's the best swap to do in the 73 wagon. But it is doable...
76hotrodpinto
I've heard talk of 45.5" Aerostar driveshafts, but but can't confirm it. The C-4 trans/6-3/4" rear driveshaft fit my T-5 trans/8" rear perfectly.  Didn't have to swap U-Joints or anything.
  I also saw on one of the car shows where the U-Joint mount and shaft were notched (as an alignment indicator). The shaft was then cut, the mounte liberated and re-welded. They said it worked well and didn't re-balance it.  My experience has been that if you search enough there is probably a driveshaft out there ready made for your application.  I have a '64 Strudebaker Daytona with a '92 GM 700R4 trans. And, wouldn't you know, a driveshaft from a '78 Buick Skylark 4 door fit just fine. So, with that in mind, here's to you "getting the shaft" - and I really mean that in the most considerate way.
76hotrodpinto
Uh-oh... new issue. I tried to fit the drive line, and it's about an inch to long. So I'm off to the yard to find something in the 45.5" range.
Been a little wet out there, not getting much done.
I used the 'Bird trans mount because the Pinto 4-speed mount was totally different. It has about about as much movement as I would expect stock mounts to have. I can see movement in the shifter in my videos, but it wasn't noticeable while driving.
The old knock sensors that these engine came with are sensitive in a specific frequency range. It is possible to trigger them with impact, but I kind of doubt the engine rubbing on the frame would cause enough to do it, especially if there is not enough "slap" to cause very audible vibration.
I'd agree that the trans mount feels too soft. It probably doesn't help that it is 42 years old either. I would guess that there are stiffer urethane mounts available. I'm guessing it is a pretty generic mount design given the 3 speed automatic mount bolted right to a 15 year newer 5 speed.
Regarding the knock sensor, can it be triggered by the engine vibrating on the suspension?  I had to notch the rubber on the (passenger side) rack mount and then indent the strap just to get a little clearance on the starter rear bushing. Then or the rearward strap bolt I had to grind off about half the heads thickness for clearance on the bottom of the starter. Even after that I still barely have any clearance. At times, under acceleration you can feel the engine vibrating the car as the engine twists in the mounts. And, it seems to me the power lies flat.
76hotrodpinto
Quote from: pinto_one on June 01, 2015, 05:35:17 PM
On my VSS sensor I took off my 90 bronco II and took the cable too, yes it does fit the pinto speedometer,
Brilliant! I'll put that on the next yard list. (is that on a specific model?)
On the egr, I agree it is aesthetically unpleasing. I would be happy to delete it for only that reason.
I am pleased with how much of the new wire and boxes I've been able to keep under the dashboard. I like the uncluttered look. All the relays and computers and such have their own rack up under there now. I managed to keep my glove box too.
Anyone with the wc t5 ever use a more stiff trans mount? The stock one seems just too soft for my taste.
Quote from: 76hotrodpinto on June 01, 2015, 01:34:56 AM
So that size would tie in the yolk that fit into the wc t5 to the mustangII driveline?
I don't know what size the '87-88 yoke is. I used the '86 'Bird yoke, which is a 1310. The stock Pinto rear is a 1310 (and so is the MII rear I got), but my drive shaft came from a much later Mustang that had 1330 ends.
QuoteI'm having a hard time not buying a rotated intake and going with a front mount intercooler. The only issue I'm concerned with, is the egr tube. If I delete it, will it have an adverse affect on my motor, or the computers ability to run it correctly? I have the pinto alt. bracket installed, and it's just saying"front mount intercooler... front mount intercooooler. ..".
You and me both.
Except in my case I've already decided to do it. Plus side is that it will help everything fit under the stock hood.
Deleting the EGR won't cause anything to go haywire. The ECU will always report a trouble code pertaining to an EGR fault, but it won't cause a measurable change in how the engine runs. The ECU will pull timing when it detects knock (that you can't hear) as long as the knock sensor is still there. Many report that too much timing gets pulled causing the power to nose-over noticeably and yeah it can, but it's it's keeping things together and is really fairly transparent given the state of technology at the time.
I deleted my EGR and can't say I've had any adverse affects from it. That said, I haven't run without it much (my Pinto sees maybe 500 miles a year).  My reason for deleting it was not functionality. It was more so that it freed up a lot of space and aesthetically looked better.  Some have wondered if it would increase combustion chamber temperatures. At least audibly I can't tell that pinging and detonation is present.
76hotrodpinto
Quote from: 65ShelbyClone on May 30, 2015, 05:32:17 PM
The type of u-joint for mating different yoke sizes is called a combination u-joint. The most likely one you would need is a 1310/1330 combination and they are widely available from many manufacturers.
I'm having a hard time not buying a rotated intake and going with a front mount intercooler. The only issue I'm concerned with, is the egr tube. If I delete it, will it have an adverse affect on my motor, or the computers ability to run it correctly? I have the pinto alt. bracket installed, and it's just saying"front mount intercooler... front mount intercooooler...".
You might be better off using a cable and VSS from another car like an '87-93 Mustang. They used a cable for the speedo and had a separate VSS for the EFI/cruise control that it fit into on the trans end. I just don't know if the speedo end would fit the Pinto cluster nor if the pulses per revolution is the same.
http://www.americanmuscle.com/pyi-speedsensor-8793.html
76hotrodpinto
Quote from: Wittsend on May 29, 2015, 11:13:15 AM
The removed panel look very similar to what I did. I used a little Bondo to blend the new panel. I was apprehensive to do so, but 7 years later nothing had cracked or melted.
  How is your clearance on the boost control actuator? I curved my panel downward and I still barely have any clearance.
I'm actually going patch it back in flat and flush, but from the frame, up to about 5"-6", I'm going to fab an access panel that can be pulled from the wheel side. Just through the assembly process, I decided this is a must. No clearance issues with my planned panel fitting.
The hood... well I'm just glad I have a crappy hood with a patch over an old air cleaner hole to work with, cuz I'ts getting another hole too.
I have the wiring all in place and ready to pull back out to tape and sleeve for final install. Got the exhaust tied in to my previous 2.5 system.
My clutch is on back order though. Centerforce is on sale right now, so shelves are sparse. I Got a new heater motor, but it's not what was supposed to be.
Do any of you know who makes u-joints for building mix and match drivelines? And who makes this speedo T for a wc t5?
Everything on the turbo side is effectively interchangeabl e with the turbo/manifold/intercooler from an SVO (only ever equipped with a T3), so I think any difference in orientation would be from the T3's larger compressor housing.
Stock '87-88 'Birds make full boost by ~2200-2400rpm in higher gears, so I would expect 2400-2800 in a lighter Pinto with shorter tires and/or more gear.
That is true. You can rotate the turbo intake housing around and move it a bit..., but then that throws off the alignment with the intercooler.  To that end I feel I have some premature wastegate bleed from doing so. I can get full boost, but I think the exhaust is slipping by on the way to getting there.  I should probably just cut a notch so I can set it where it needs to be and stop trying to be so "cute" with my dedicated (but movement restricted) are I fabricated for it.
I also have a feeling the 87-88 T/C's probably had the turbo mounted lower to make room for the intercooler. But, not having anything to compare to it is only a guess.
What's ironic is that the smaller IHI turbo you guys are running has less clearance than the larger T3 that I'm using which has a larger wastegate actuator. The difference is that the T3's WGA is tucked between the turbo and engine.
In fact, I think it would have been unnecessary to cut up the inner fender of my car. Would have saved a lot of work...
76hotrodpinto
Got the alternator bracket shaved and mocked up.
I got the t5 installed and the clutch cable run. Other than drilling the cross brace for the trans. mount and opening up the shifter hole a skoash, it was an easy fit. I am going to ad some more sheet metal to the back end of the shifter hole, to center it back around the shifter mounting plate.
76hotrodpinto
