77 Caliper Bolt
Date: 08/21/2018 04:02 pm
Date: 03/29/2019 07:20 am
New cam
Date: 01/23/2017 05:11 pm
Date: 11/08/2020 02:10 pm
Date: 04/13/2018 11:30 am
72 PINTO WAGON
Date: 09/23/2018 06:16 pm
Date: 11/11/2019 04:49 pm
78 hatchback
Date: 03/12/2023 06:50 pm
Date: 07/17/2018 09:22 pm
  • Online today: 2,773
  • Guests: 161
  • Total: 161
Taking the turbo plunge!
So, it seems one should be careful what bleed orifice they use if they are mix/matching parts because a little, tiny hole can sure make a difference. Which, BTW I assume the boost can be altered simply using (making) a smaller orifice? This seems rather simple and cheap over the more expensive boost controls.
The speed control and the engine RPM likely do make sense, but it must have a wide, delayed range given the action of gear changes and tire slippage.
For those of us who forgo the speed sensor for the manual speedometer, do you think there is any adverse effect to the ignition/fuel/boost the ECU is allowing?  There are some Tee speedometer drives out there (I have one for a Halda Twinmaster) if I need to reestablish it.
Lastly, what is your take on the **** referring only to the overboost alarm. http://beta.askatech.com/askatechlive/aatfileshare/references/fasttrack/f023.pdf If you look at the larger table (83-86) the notation at the bottom definately is stating such saying "pressure warning." It is my inclination to see it as such for both (also given the column it appears in) and not an indicator of actual boost levels under and above certain RPM's.
I would have kept the octane switch if I was using an EEC.
Quote from: Wittsend on May 05, 2015, 10:50:17 AM
Thanks for the link. It explains a lot. However, it pretty much comes back to what I had understood:
1. "On vehicles with a manual transmission (the LA ECU), with the switch in the PREMIUM position, boost is controlled by the EEC-IV processor, and can go as high as 16 psi depending on rpm, vehicle, speed, and transmission gear selection.
That just means that the octane switch being set on 'regular' will lock out the ECU's ability to raise boost. (Incidentally it pulls some ignition timing as well.)
Quote2. "On automatic transmission vehicles (the LB ECU), switch position does not make any difference. The maximum boost is controlled by the EEC-IV processor at all times. Maximum boost pressures on automatic transmission vehicles vary between 6 and 11 psi  depending on rpm and vehicle speed.
This is why I'm confused about the LA and LB ECU being interchangeabl e. I can't see how the LB ECU limiting to between 6-11 psi would be as capable horsepower wise as the LA that can go as high as 16 psi.
That's because absolute boost numbers aren't dictated by the ECU. The wastegate actuator is what sets the minimum boost pressure and the bleed orifice in the boost control solenoid circuit is what sets the maximum boost pressure. All the ECU does is switch between high and low, which is why an LB3 can be used in place of an LA3
QuoteAlso the **** seems to be a notation for the overboost alarm (it appears in that column) rather than an ECU control of the boost in various stated RPM ranges. That part of what Ford presents is confusing because even if it were to be debated that **** was ECU boost control or an overboost alarm point how would it be known what gear the manual transmission is in regardless of the position one takes???
I figured it out in typing this reply...the ECU determines transmission gear based on signals from the vehicle speed sensor and engine RPM.
Just so I could have gauges I quickly made a gauge mount out of a 2X4 and some strips of wood for the T/C gauges.  As things go, I'm still using it and then eventually tacked on the Premium switch.  Not ideal, but functional.  I have too many cars to perfect just one.  I've got the three pod factory gauge set that mounts in the heater control area, but that is on my "some day" list.
76hotrodpinto
I think I'm going to keep mine as well, just switch the switch to something that matches my style more. Something more toggle-ish.
I have kept my premium switch. Without it engaged the ECU works at lower boost levels for "Regular" fuel. I'm sure you can hardwire it as long as you always bought premium fuel. For whatever reason Ford has a relay in the switch wiring system.
As far as I know 65SC is running an aftermarket system and I think it completely bypasses the EEC - IV system. His inclination is on a good dose of power where as my goal was to economically transfer over the '88 T/C system "as/is."
76hotrodpinto
Are you guys keeping the premium switch, or bypassing it?
This is why I'm confused about the LA and LB ECU being interchangeable. I can't see how the LB ECU limiting to between 6-11 psi would be as capable horsepower wise as the LA that can go as high as 16 psi.
This is the turbo boost specification for all the various 2.3T models. It says boost was allowed to hit 15psi in 1st and 2nd gear for the '87-88 TC, but there was no way that the ECU could know what gear you were in.
OK, I'm not trying to dispute here, I'm just confused. I had a friend with an Auto 87 TC and recall him saying the HP was limited to about 165 or 175.  His 87 Auto car also had a single exhaust as opposed to the dual of the 5 speed.  If the LB computers are compatible (and by that I mean plug N' play equal HP) with the LA's where does the different HP ratings between the Auto and 5 speed cars come from?
I always thought (by what I read) that the LA-3 (and "P_" SVO series) were the most desirable ECU to have.  I have shied away from the LB series believing they were less desirable that the LA's. And, I even sold a LA-2 thinking that the LA-3's were better.  All a mote point now, as I have an LA-3 in the car and two more LA-3's stashed in my "private reserve." But now I'm feeling a bit foolish if my LA-3 ONLY quests were being unnecessarily persnickety.
Quote from: 76hotrodpinto on May 04, 2015, 12:44:19 PM
Is there a way to tell if the tbird is setup with system that allows full boost in all gears, or the one that limits 1st and 2nd?
All of the cars that allowed for a"high" boost level of 14-15psi also had a limiter of sorts. The system actually limited boost to the baseline wastegate spring setting (~10psi) below 4000rpm regardless of gear. An EEC-IV had no provision for sensing what specific gear the trans is in. You can make it run full boost all the time by simply bypassing the boost control solenoid.
On the other subject of transmissions, my 'Bird had a speedo sender. Mustangs with WC T5s had a cable for the speedo and a speed sensor for the EFI and/or cruise control.
Quote from: Wittsend on May 04, 2015, 01:15:07 PM
The 5 speed ECU for the 87-88 cars was LA-2 and LA-3 respectively. (snip) These two ECU's were deemed to have a faster processor over the 86 and older. I'm not sure what the SVO ECU had, but I believe the 5 speed version was rated at 205 HP VS 190 HP for the 87-88 T/C 5 speed.  Probably a bit of apples to oranges comparison given various parts differences.
There are also LB_ ECUs that came in the same TurboCoupes and they are interchangeabl e with the LA2/3. SVOs all had the older P-series computers.
Only the '85.5 SVO was rated at 205hp. It was derated to 200hp (on paper only) for the actual '86 model year so the '86 GT 5.0 would look more powerful. The '84-85 SVO was only rated at 175hp. There are actually a lot of differences for such a short-lived, low-production car. The SVO's story is a neat one and fascinating, but ultimately tragic.
Putting an SVO T3 turbo on an '87-88 Turbo Coupe would effectively upgrade the engine to complete '85.5 SVO spec. Putting an intercooler on my '86 engine would do the same. A stock non-intercooled 2.3T at 15psi is good for about 170rwhp.
That is an interesting question. With the T-5 I only recall the back up light switch and the speedometer wiring. So, how would the ECU know what gear you are in???  Maybe for the Automatic cars there was boost limitations? I have heard such, but only having a T-5 car I can't speak from experience.  The 5 speed ECU for the 87-88 cars was LA-2 and LA-3 respectively. For the automatic cars I'd think there was likely an on/off type switch and either by completing or defeating a circuit (however Ford did it) the ECU can be fooled??? Regardless of what was done in the lower gears it was my understanding that the final HP rating for the Automatic cars was about 20 HP lower than the 5 speed cars. Hopefully someone can confirm this.
76hotrodpinto
76hotrodpinto
I don't have my mind set on the hydraulic clutch, but it would be so nice. The cable is easier to install, but I've stuffed a few master cylinders in some dark corners before. I need to decide fairly soon though, so I can get this party started!
A clutch master cylinder under the dash is feasible, the first link shows one method.  The second link covers non-OEM clutch hydraulic replacement lines for use with a 87-88TC hydraulic clutch slave cylinder.
http://www.pro-touring.com/threads/71950-My-74-Turbo-Pinto-little-bit-different/page3
http://forum.turboford.org/cgi-bin/ultimatebb.cgi?ubb=get_topic;f=2;t=058523;p=0
The reverse clutch M/C is a possibility, but frankly the bell crank is simple, straight forward and available. I feel you would be reinventing the wheel to go hydraulic.  And again, space might be tight. That general area under the Pinto dash I packed with the cruise control and intermittent wipers stuff so I be hard pressed to see up there and advise on the hydraulic feasibility.
76hotrodpinto
On the clutch subject, I'm toying with the idea of a different master cylinder, with similar capacities as the tbirds, mounted backwards up under the dash, like up near the dash bracing. That way the direction of travel at the top of clutch pedal will match the direction of the reversed master cyl. Then run the line out and down.
My '88 TC donor had the electronic speedo even though the face was typical analog. So, I'm thinking they all were electronic.  A word of caution...,  I used the gear from the C-4 on my T-5. It had a tip on it and when clamped down it caused the gear to bind on the opposite side of the housing.  The end result of that was the gear on the output shaft forced itself backwards - out of mesh. Prying with screwdrivers would not get to clip to snap back into place.  I was almost going to pull the tailshaft when I found that the vertical tube of 90's era halogen "torch" light just fit over the shaft and inside the bearing. A quick whack and the gear was reset. However, I did cut the tip off to avoid the binding.
I also cut up the T/C fuel/return lines, part of the line is plastic and needs to be shortened. There is a barbed repair coupler I used to join the cut parts.
Don't waste any time considering the hydraulic clutch. It is an oddball configuration that internally parallels the steering column and has no allotted space in the Pinto.  Get the bellcrank housing. You will need to elevate the cable mount over the crossmember, but that is easy enough with a piece of flat steel.
Here is a link to my two part build. Perhaps some of the information is helpful. http://www.fordpinto.com/index.php?topic=11908.msg76893#msg76893
Lastly here is a shot of my engine compartment with the '88 T/C harness (and stock Pinto harness). Quite a few wires even when encased in the plastic wrap. Especially around the master cylinder.
76hotrodpinto
Quote from: 65ShelbyClone on May 03, 2015, 01:15:38 AM
It doesn't matter; a manual Pinto cable and gear ought to fit in the T5 just fine.
FYI, World-Class T5s came in '86+ cars. I have one and you have one.  :D
So the wc t5 comes with both mechanical and electrical speedo out? I was under the impression the wc were electrical and the non-wc were mechanical. I like the idea of the wc t5, much tighter feel to it.
76hotrodpinto
I wasn't able to stuff myself to far under it yet, so I'm not certain the trans has a mechanical speedo output, or electrical. Anyone able to say with certainty, one way or the other? My understanding is that's only on the world class t5, this should have the non-world class t5... right?
If you think the 'Bird is quick as it is, try that driveline in a car that's 800-1000lbs lighter.
Quote from: 76hotrodpinto on May 02, 2015, 11:33:28 PMAnd are you guys running thru the existing fuel lines and just clamping flexie efi lines off them, or flaring them out for compression fittings? Or?
I'm using the stock steel lines with some mods, but there are numerous options for plumbing the fuel.
76hotrodpinto
I took the tbird out for another ride. Man, that thing is pretty quick, for a boat! I did a bunch of staring and smoking today. I think I got the harness situation mostly figured out. I got to start today by replacing the fuel pump relay. I'm going to do the mods in the tbird to make it easier to just swap over. I did notice a hydraulic clutch though, that's going to take some more staring and smoking. And are you guys running thru the existing fuel lines and just clamping flexie efi lines off them, or flaring them out for compression fittings? Or?
Here's a couple pics of my donor.
Quote from: 65ShelbyClone on May 02, 2015, 01:38:11 PM
Ford apparently made the '87-88 Turbo Coupe harnesses into one big integrated part that carries wiring for a lot of other non-engine systems. Wittsend has an opinion on using one in a Pinto as I recall.  ;)
For sure on that. After I pared everything down that seemed non-essential I still had about 20 "not sure" wires. And that pared down took days.  I'll included a shot of the harness as it relates to the dash. Now to be fair I opted to used the T/C steering column/fuse box etc. - but still.  Basically I wanted the engine management free and clear of the stock Pinto wiring.  Thought I'd avoid problems that way. LOL  NOW..., I'm inclined to think I'd have been better off leaving 6" at the end of each connector and just soldering wires as needed.  Live and learn.
The radiator I'm 99% sure is too big.  I did bump my '73 17" to 20" but I assume you already have the 20".
As far as the rear end, I have the inverse. To have the T/C carcass hauled away I welded the Pinto 6-3/3" rear. So, you can somewhat visualize the difference.
Quote from: 76hotrodpinto on May 02, 2015, 09:02:41 AM
Is there any info out there on the harness mods to run it in the pinto?
The info is pretty much "use something else."
I used the ECU harness from my '86 donor car and it was still a major project paring it down to the bits I needed. It may have been less work to keep the emissions-related stuff had I used a stock ECU.
76hotrodpinto
Quote from: 65ShelbyClone on May 02, 2015, 08:51:54 AM
That 'Bird has upper and lower control arm rear suspension. You could cut all the brackets off and weld on spring perches, but the rear end will still be about 2" too wide on each side. However, something the '87-93 Mustang crowd would do (if I recall correctly) is use the Mustang axels and somehow flip the caliper brackets in order to use the TC rear under a narrower Mustang. FYI, your donor car will have 3.55 gears if it's a 5-speed and 3.73s if it's an automatic....and a Traction-Lok in either case.
The radiator is way too big and won't fit without major mods. The fans might have potential.
It's a 5sp. I thought the rad looked too wide, but I haven't had the time to check all that out yet. I'll stick to my current 8" and do a disc conversion later. Maybe I can re-coupe (get it?!) some money, by selling that one. Is there any info out there on the harness mods to run it in the pinto?
76hotrodpinto
Well I have 2 blocks, 3 heads, 3 turbos and whole 87 turbo coupe donor that runs great! I think I'm ready to start the swap now. Will that disc brake rear end and radiator/fan setup from the tbird fit my 76?
Many Fox3 vehicles, especially Mustangs and T-Birds, have the coil hidden under a plastic cover on the driver-side inner fender...if the cover is still there.
76hotrodpinto
I learn something new every other week. I'll look for some the next time I make a yard run.
"E-core" coils have epoxy-potted cores. While oil helps cooling in old-style coils, it is there more to act as an insulator. Epoxy coils have the iron pile eposed and don't need special cooling measures when driven as intended(usually an ECU or coil driver with dwell control like the original TFI module or a GM HEI).  The ones that Ford used with EFI are better known as TFI coils and are blockish in shape. I'm using the one that came out the '86 Thunderbird donor. Just be aware that they use a special plug with spade terminals, not posts like a regular coil.
On a side note, I have the oil-filled coil in my Mustang mounted on its side and the TFI coil in the Pinto mounted upright.... ???
