Date: 09/01/2017 11:58 am
Pinto Fiber Glass Body Parts
Date: 01/06/2019 06:53 pm
Date: 10/24/2018 07:35 am
1978 Squire wagon 6 Cly
Date: 03/08/2021 10:44 am
Date: 08/09/2018 11:09 am
Date: 04/08/2018 05:47 pm
WANTED Hood Prop Rod
Date: 01/17/2017 02:47 pm
Date: 04/13/2018 11:30 am
Various Pinto stuff for sale.
Date: 11/21/2018 01:56 pm
  • Online today: 3,109
  • Online ever: 3,109 (Today at 06:23:23 AM)
  • Guests: 2905
  • Total: 2905
Aaron,
That sounds like a plan. Aaron is the lead tech at the shop :) He will also own this in a few years to 5 I hope!
Dianne
Use the shifter arm out of the C-3 on the A4LD , that way you can use the stock shifter and file the extra detent on the shifter , the rod just shortened 4 1/2 inches, best is you do not have to remove the valve body to do it , keeps it stock looking
Quote from: pinto_one on February 06, 2016, 01:18:55 PM
Glad you got it running , you used the auto overdrive in it ? Guessed since you cut the transmission crossmember you did , good mod , still like mine , how is your 73 wagon coming , like to see when you get that done , have a good one , Blaine
The 73 is coming along, need to find clips and stuff. Posted a pic also in that build :)
ahuffman_09
Yes we are using the a4ld. wagon is back at the shop ready to get interior put back together.
ahuffman_09
this is where you hook switched power. This is a soldered connection covered in tape from the factory.
this is your ground. they are all black with green stripe.
https://youtu.be/Tfv7P6_BaIY
It's been awhile. The 79 Pinto is running with the fox body motor. This has been a task and trying to get it done with a little time. But here it is running.
https://www.youtube.com/watch?v=DfFESUN9e48
Also, I cut out the transmission mount I welded in and an now going to redo it. This is basically going to be my daily driver.
Quote from: r4pinto on August 15, 2015, 08:38:07 AM
looks good but is it going to be too low to the ground? I'd be concerned of bottoming out since the Pintos are pretty low to the ground as it is.
It should be fine, not that low. I can take a pic after I get the driveline back and see where I am at that point. But seemed fine when it was off the lift and measuring the driveshaft!
Quote from: pinto_one on August 14, 2015, 07:55:48 PM
Nope , I used the stock mount that came with the car , (2.8 V6) you have to cut away ALL of the old pinto mount one the car to clear everything, if the car had the C-3 the yoke will fit the trans only you will have to shorten the drive shaft 4 and a half inches , the pinto neutral switch will plug into the trans you have , no mods there
Yep, the drive shaft is off to being done now and yeah, I think it was that. The mount you see in mine is from this Pinto, much different than the 2.8 one. Yours looks pretty identical to a Mustang II. Mine will hold, I don't like it and will probably change it later. I have a Mustang II one laying around from a 2.3 so the exhaust is different than yours, but since mine is a 2.3 it should work. Not too certain yet on how or if I am even going to do it Blaine.
Yours does look nice!!!
Quote from: pinto_one on August 14, 2015, 06:21:57 PM
Hey Dianne did you look on my gallery photos and see how I done mine , out of the way and not hard to do ,  later Blaine
That looks good actually Blaine. After doing it we saw like 50 different methods LOL. I may change it later, just wanting it on the road now.
Mine was also harder probably. Did you use a Mustang II mount?
After we did it it would probably be better with two plates to the side an angle with round tube and bolted to the old mount, but this will work fine. Its a daily driver not a show car.
The transmission is a A4LD.
This is how I'm building the new transmission mount in the 79 Pinto.  Just got some 1 inch square tube. That's now welded to the frame taking the old frame mount out and cutting some of it off and Welding some steel plate to those two frames that will bolt through the transmission.  this is a daily driver so I'm not that worried about how it looks. No one will see under the car. The EFI and the new transmission are definitely different. This is the best way I can see you to do it. If I had the plasma cutter setup and program running I could probably cut out something pretty cool. But since it's a daily driver it's all good.
Quote from: r4pinto on August 02, 2015, 08:50:53 AM
Which is always good for me. Give me EFI & I can do anything. Give me a carburetor & I tend to be rather braindead.
Well, carbs have to be adjusted :D
Quote from: dianne on August 02, 2015, 08:47:56 AM
It's just a better running option also is what I should have said!
Quote from: r4pinto on August 02, 2015, 08:38:58 AM
When you work 40 minutes from home you always worry about MPGs :P
Quote from: Reeves1 on August 02, 2015, 06:34:59 AM
There is an oil glut right now......stop worrying about MPG !  ;D
LOL
And it's more fun and a better setup :)
Quote from: r4pinto on August 01, 2015, 08:58:21 PM
Any idea what the HP and MPG differences are between the EFI 2.3 versus the old carbed 2.3? Reading this post has got me thinking about doing it on my 80. Also are there any clearance issues with the hood with that intake?
It's about 90 for the EFI and about 88 for the Pinto 2.3 (or T88). The big thing is the MPG that it will get with the 2.3 EFI :)
Thank you!!!! This beats $500 of parts!
Inline pump from a F-Series Ford pickup (probably mid to late 80's). Six or so years ago it was $11 from U-Pull Parts. I used the fuel filter, relay box and impact shut-off switch from my T/C donor car.  Just a word of caution.  Some of the F-Series truck had a low pressure electric pump to bring the fuel to the high pressure pump. If it helps my pump was mounted on the trucks frame rail about where the door is. There are only certain years that used this inline pump. At some point they went to an in tank arrangement.
Don't forget there needs to be a return line. Some use the tank vent line but I ran a separate return by drilling and soldering into the sender unit housing.  That melted the nylon electrical seal, but JB Weld fixed it up and six years later, no leaks. Both my pressure and return line were fashioned from modifying the T/C donor cars fuel lines.
how did you guys do your fuel system? Is there an in tank pump option or just in line pump?
Yep, saw it :) Thanks!
Cutting it out and making a new mount :)
Dianne
You can look at my transmission mount under the pinto gallery members photos, but the transmission tunnel is smaller on your wagon , they are a few here that has a much simpler mount for your wagon when they done it, I done it that way to make the duel exhaust pass easier to the back,  you have to cut ALL of the transmission metal out from the tunnel, or your shifter rod will touch it on one side and your cooler line and vacuum line to the modulate r will hit on the other, drive shaft will have to be shortened 4 1/2 inches, same for the shifter rod ,
Quote from: pinto_one on June 23, 2015, 07:57:31 PM
Not to bad , just have shorten it some and toss what you don't need , best is to look at the wiring diagram (colored coded in real color) on a table in a quite place , and take time to look it over , you will see how simple it is
You know your stuff is in this car :D That's your pan. I'm going to use the mounts in the wagon. This is a good opportunity to learn for the wagon. It's a lot of work. It's getting an overdrive transmission also. I'm going to weld the new transmission mount soon. It's gotta get the driveline changed also. It's a fun project!
Thanks for all the help :D
It's getting closer and the guys figured out how to do it now and are laying out the new fuel lines for the EFI setup. They are going to use two fuel pumps with different flow ratios (gallons per,,,) and that will be done!
It is a process :) I'm stuff doing service orders now and we're moving the shop opening on the 13th of July. I'm hoping this is done before we move :)
