Two 1978 Pinto Station Wagons
Date: 05/18/2025 03:10 pm
Date: 09/17/2024 12:35 pm
Custom Pinto Project
Date: 06/12/2016 07:37 pm
Pinto Fiber Glass Body Parts
Date: 01/06/2019 06:53 pm
72 pinto
Date: 06/23/2016 12:40 pm
Wanted early pinto
Date: 10/03/2019 02:42 pm
1979 PINTO PARTS--FREE
Date: 09/13/2022 02:05 pm
72 Pinto parts
Date: 12/04/2018 09:56 pm
1976 Ford Pinto Pony
Date: 09/06/2018 05:40 pm
  • Online today: 3,214
  • Online ever: 3,214 (Today at 10:48:59 AM)
  • Guests: 2823
  • Total: 2823
Not to bad , just have shorten it some and toss what you don't need , best is to look at the wiring diagram (colored coded in real color) on a table in a quite place , and take time to look it over , you will see how simple it is
Wiring mess :)
Below is a link to a 1988 Mustang EVTM.  Might be close enough for the 1987 ecm, but look for discrepancies.  For a exact match, hard copy EVTM's can found on ebay.  See page 26 in the link for the main power and ground connections.  Note their are several levels of power and grounds used to avoid electrical noise and circulating currents, so it is good to watch the details.
http://home.comcast.net/~smithmonte/Auto/1988_Mustang_EVTM.htm
ahuffman_09
I've searched and couldn't find anything but does someone know what wires on the ecm i need to tap into for power and ground?
Quote from: pinto_one on June 17, 2015, 05:54:11 AM
I think I used a 55 gallon drum full of parts when I done my 76 , almost got the other drum full enough to start working on my Cruze wagon , 😜
You're crazier than me ahahahahahahahaha
Well, I can't wait to see what happens with the new flex plate :) Then it's rewiring.
This probably should have been under the 79 Pinto build to help someone else.
Quote from: 74 PintoWagon on June 16, 2015, 09:52:19 PM
A bucket of parts from different years and models makes for an interesting puzzle, lol.. :D
It sure had, I can't wait to get to the turbo in the wagon LOL
No pilot bearing. Something is not lining up. But again, we have a c4 going in tomorrow I hope if the flex plate gets in. That was going in the wagon on the turbo project, but now that's going manual :)
 Was the crank ever sent out to be turned? Often they just do an exchange. And, if the crank came out of a manual car the pilot bearing might still be in there. This is just a shot in the dark, but stranger things have happened.
Ok , I guess we got some confusion here , I know the C3 and 4 are very different , thought the original problem was you could not get the 79 C-3 trans from the pinto to bolt to the 89 2.3 out of a mustang , it is supposed to work,  botton line ,  but guess something happen to it when you had it apart , but since you got a working C4,and can get it to bolt up go for it ,  kind if hard to help when you can't touch it and your almost a thousand miles away ,  but good luck, let us know what happens ,
Quote from: pinto_one on June 16, 2015, 11:21:19 AM
Are you sure you have the right converter, I did notice you had a A4LD on the floor that came out of the t bird for your pinto wagon project , make sure it did not accidentally got the converters mixed up , the converter is a inch longer , that is all it can be , to bad I am so far away to look myself , I do like to solve mysterys ,
Yes, positive. The C3 came out of the Pinto and the C4 was out of the Mustang. Honestly, they are different and I know what came out of the Pinto and the Mustang ;) It's annoying to be honest and the flex plate won't be here until tomorrow :(
The converter is seated. It just doesn't work. The C4 should resolve the problem...
I'm certain my guys will read this. He knows his stuff, but maybe he can try again...
They said they even tried to bolt it up to the engine with out the fly wheel and still went into a bind , I still believe that they have not got the converter fully seated into the pump gears , forgot about the seal , early ones used the rope , but ford motor sports had a two piece one to change over , and you are right on all of them sticking out the same on the trans side
Their is a  difference between the 79 and 89 cranks but it should not affect bolting up the transmission components.  The 79 uses a two piece rear main seal and the crank has a oil slinger built in to help keep oil away from the seal.  The 89 uses a more efficient one piece rear main seal and the crank does not have the oil slinger ring.
As a investigation procedure, have you tried bolting the flex plate on the crank and then the torque converter to the flex plate without the transmission?  You might be able to see if the interference is coming from converter snot.  Final assembly should be with converter seated in the transmission and then slid forward to bolt to the flex plate (stated to avoid confusion).
They dies in the mustang II also , most were people that never left town and stuck in traffic with the A/C wide open on a hot day,  that back then came with the first joke about the pinto ,   Put IN Transmission Often, happen to me, alway stuck in the New Orleans traffic, stop and go and the seals got hard as a rock and lost pressure inside then burnt clutches , installed a larger pan and a oil cooler , problem gone ,
They did good in the Mustang? What's the difference between the two? Do you know why it gets kills in the Pinto and not the Mustang? There are oil cooler lines on the C4? Should I just put in an oil cooler?
Quote from: pinto_one on June 15, 2015, 09:03:52 PM
they make a nice oil pan for the C4 that holds a few more qts of trans fluid and has small tubes to help with some cooling , heat alway killed the C4 in the pinto ,the small torque converter made lots of heat and burned them up in stop and go traffic,
It's probably the same as the one in the Mustang II, but that may have been modified for the mini stock. I'll look into that! Thanks! Do you know what the one was? Where did you get your pans?
Quote from: pinto_one on June 15, 2015, 08:07:38 PM
Which trans are you going to use ,  and also the the 2.3 cranks are the same from 1974 up to late or early 88 , then they reduced the main bearing size , it stayed that way until the end of the run of the engine,
This one is an 89. Going to go with the C4 when the flex plate comes in tomorrow :) Better transmission anyway :)
Quote from: pinto_one on June 15, 2015, 06:19:47 PM
The C3 and the C4 flex plates are very different , and having piles of parts in the shop just waiting to be mixed matched , priceless,  that is why I use aircraft safety wire to tie things that must stay together for future projects, the C3 not bolting up to a 2.3 that was once bolted to a2.3 sounds like a good story for a book deal in the future to sove this mystery or sabotage, the plot thickens, 📝👀
LOL and it's thick :) The new flex plate gets here tomorrow. It looks like the cranks are different also in the 79 Pinto and the 89 Mustang...
Quote from: pinto_one on June 15, 2015, 04:50:14 PM
Well kind of hard when you can not see it, and guess since it was taken apart and all the peaces were kept together , it should work, unless you have in the shop a A4ld that was taken out of a efi mustang or thunderbird and the converter ended up in the C3 , yes it will go in, but it is an inch longer, the c4 bell housing will have to come off a 2.3 , rare, but if you have one off a 2.0 you will have to use stepped dowels, to center everything up, do not leave the dowel out , it will wear out the pump bushing in no time , good luck , and I hope you find why , later Blaine
The transmission was taken out of the Pinto and everything kept together. If you look up the flex plates for these you'll see how different they look and the C4 flex plate has a concave some. Weird...
ahuffman_09
i've even pulled the converter and rotated it 180* and reinstalled it. trust me the converter is seated all the way. it is not my first rodeo. i have discovered that the c4 bellhousing is longer than the c3. and the converter pilot is not mushroomed. i think you are misunderstanding me. the pilot doesnt get jammed the crank bottoms out on the converter pilot. i think it would need a different converter and/or the bellhousings swapped in order to work. but the c4 will be going in so problem solved.
Quote from: pinto_one on June 15, 2015, 04:22:24 PM
Well something has changed , the 2.3 cranks shafts are all the same, the converter may have been dropped by accident and not one knew about it, might want to find a trans shop and find a pump gear to test that , a C3 or A4LD will work,, next you will see a taper one one side of the gear , that is to help in alinement to engage the converter, I have found a few installed backwards and they will still work but a bitch to line up, those I stood on the tail shaft with the belhouseing pointing up, and put in the converter and spin it until it drops in the rest of the way , good thinking on trying it with out the flywheel , just make sure the stub shaft on the converter slides all the way in the crank to make sure , that end will bend also when dropped , had a few bite me,s over the years on that also , hope this helps ,
Nothing was dropped Blaine. Aaron actually took the converter out and marked the orientation of the pump drive, put the converter in and rotated 90 degrees and then took transmission out and saw that the pump rotated 90 degrees.
We looked up the crankshaft for these two years, the 79 Pinto and the 89 Mustang engine, and they have two different part numbers. I'm guess something there is different. So in goes the C4 I guess. Then I can convert to a T5 and make the wagon a standard with the turbo :)
