Clutch pedal needed
Date: 01/11/2024 06:31 am
Date: 08/20/2017 01:34 pm
Date: 03/06/2017 01:19 am
Esslinger 2.0 intake
Date: 03/06/2017 11:58 am
Seeking parts
Date: 10/18/2020 10:35 am
Wanted 1973 Ford right fender
Date: 06/03/2017 08:50 pm
1977 Cruiser
Date: 06/29/2019 06:28 am
1980 cruising wagon ralley
Date: 07/12/2019 01:41 pm
79 pinto small parts
Date: 04/24/2019 03:16 pm
  • Total Topics: 16,268
  • Online today: 160
  • Guests: 153
  • Total: 153
2.3 EFI 1987 Mustang Pinto swap into a 79 Pinto
Started by dianne, January 25, 2015, 01:02:36 PM
74/80 front springs will work after CUTTING some coils off as they are longer than 71/73 springs. As you cut them, they will get stiffer and may make your wagon ride like one of my race cars. Only one way to tell. If your springs are sagging and too low you can buy spacers to put under the springs. They work good and can be bought at front end shops cheap. If your wagon is factory air, it came with the biggest springs Ford had in 73.
fox body springs will not work, they have struts , got a set ,(well one of them) have to find the last one, I think you may have to cut a coil off to shorten it, after 73 they got a tad bit longer,
dianne
Coolness! Do I need to pick up two Mustang Fox Body springs?
Vehicles:
- 1976 Mustang II mini-stock
- 1978 Mustang King Cobra II
- 1979 Ford Pinto Runabout
- 1986 Chevy K5 Blazer
- 1997 Suzuki Marauder
Hey that look pretty clean inside, that is going to be a cheep over haul, and soon you will need these ;D,  digging up a box so I can send them to you ,  later Blaine 8)
dianne
This is the engine torn down. I just wanted it refreshed LOL Guess they took it all the way down...
Vehicles:
dianne
They are getting closer.
The Pinto will be back from paint on Monday :) I need pictures :)
Vehicles:
dianne
These are the guys getting ready to tear the engine apart. It's filler work, but I'm ok with waiting :)
Vehicles:
dianne
Quote from: pinto_one on January 28, 2015, 10:33:27 AM
just to let you know I found the other engine mount this morning , still have to find the oil pump pick up tube and two front springs , I have only seen one compressor like yours with the serpentine clutch, long ago, a few years ago looked for one and they were pricey $$$ guess when you get the A/C brackets from me you could find one to test the fit and see if the belt will line up with the pulley on the engine, let you know when I dig up the rest so I can box this up and send it all to you , so around Monday or Tuesday at the latest ,  :D
OK, I guess I'm in for some other surprises when this engine goes in. PM me with everything :)
They haven't gotten to this engine yet, I'm gonna be last and my King in my shop right now and the Pinto at the painters. Hopefully they will get to it soon.
Vehicles:
dianne
Quote from: pintoguy76 on January 27, 2015, 10:17:01 PM
I used all the mustang accessories on my 91 2.3 swap into my 74....includin g the ac compressor and internally regulated alternator... Kept the serpentine belt system as well. It looks nice and modern and works very well.
You will need a front sump oil pan, with the pickup tube and the dipstick and its tube. You may have to drill the hole for the pickup tube in the block and plug the old hole (I did with my 91, but your 87 might have the hole there still, not sure)
Well OK, Aaron, Matt, and Alex, let's take a look at this and see what we need to do. I want all the new stuff in the Pinto :) The modern look in the Pinto would be cool!
Vehicles:
dianne
Quote from: pinto_one on January 27, 2015, 11:13:48 PM
This is going into a 73, also got the stock compressor, which is v belt , the serpentine is hard to find and $$$$,for that compressor  (unless you got one to donate )
I have most of the orginial AC stuff for the factory air. I need the stuff for the new setup. I want to keep the serpentine belts also!
Vehicles:
dianne
Quote from: pinto_one on January 27, 2015, 07:46:31 PM
great, I managed to dig some before it go to dark, got both side rail mounts, and one engine mount, have to dig the the other stash places for the other , also got all the brackets and adjustment pulley for the A/C, could not see much of the front of the engine , does it have V belts, if not I have dig up some pulleys for you , Blaine
I'll take some pictures tomorrow :) That's awesome! This is pretty cool and I'm excited as all heck!!! LOL
Vehicles:
dianne
Quote from: pinto_one on January 27, 2015, 12:12:13 PM
Great on not scratching the paint,  but  let them know that you have whips and chains on standby ,  ;D
Aaron's wife is my admin assistant. She'll beat him to a pulp if he scratches that new yellow paint!
LOL
This is the engine.
Vehicles:
dianne
Thanks so much again for the help. Aaron has read this this morning. The engine will be there any day now, maybe this evening.
I do want the oil pan and any of the parts you have there and let me know. We are going to do an engine refresh on the motor, so all gaskets will be replaced :)
Thanks again,
Dianne
PS - Aaron and the crew will NOT scratch any paint ;)
Vehicles:
 I will look this weekend to see if I have any extra mounts in my stash of pinto parts, have to look in the back of the parts car to see if I can find the pick up tube to go with the oil pan, and anyone reading this post that has a 71 to 73 pinto and has the 2.3 swapped into them send Dianne some photos so her guys and get the idea how to do it, as said a picture is a thousand words (or hours saved in our case ) , and once you put a hole in metal it is hard to take it back , ask me how I know  :o
dianne
I need all the mounts...
Thanks,
Dianne
Vehicles:
dianne
Do we need another oil pan? I want it if I need it!
Aaron, you should see this all now...
Dianne
Vehicles:
If you need a oil pan let me know I have one and also I have extra brackets to mount the A/C compressor to the engine if you want them, it will fit the stock compressor and lines you have now, (done it before ) so you can still have A/C , You might as will drive cool and be cool at the same time driving you pinto 8), this photo is looking down on the left side mount with the engine installed , hope this helps , later Blaine
this is the right engine mount on the engine , and also you have to have the front sump oil pan, the efi engine in the fox body is in the rear
guess I will have to send a photo at a time, it will only let me send one at a time
Hey Dianne, here are the photos of the mount I took for you
dianne
That's what I want :D  I am going to do the seats in black and yellow :)
Vehicles:
Same here with old butt getting old and want a good seat to fit the wrinkles on the back side, if you are going to redo the inside to match you should fid a good seat guy that is good with cutting new foam for the old seats , the foam I use on aircraft is called temper foam, we replace the 50 plus year old foam with this stuff, the heat from your body makes it soft in spots and fit the wrinkles on your butt, nice when you sit for hours in one spot flying along , also you can make the seats look stock but have the feel of a high end car,  ??? 8)
dianne
Thanks bunches!
I'm pretty excited :-) I have to think about seats, I want them black with yellow, but something more comfortable. Do you know what seats are good for these and are comfortable? Not too modern looking, but comfortable also. I'm old, so comfort is king! LOL
They should be able to fabricate something. I'm having Aaron and Alex look. Alex welds and does transmissions. So tomorrow I'll know what it has with it. It's auto like mine. I think I'll need a new shifter though, we'll see. Aaron will refresh the motor and Alex can fabricate what he needs. These guys, Matt also, are skilled. They are doing a 6 to 8 on a Jeep, first in the valley to do the swap. Wiring is hard because a lot of splicing on the harness.
Vehicles:
Great, what trans is on the efi 2.3 ? , if it is a A4LD, give Rebolting73 a shout for photos on his rear trans mount, he also has the 2.3 in a 73 with the over drive, he done a nice job , if you have it use it, with change the way the car is on the hwy, will try to get the photos for you tomorrow,if I don't slip and bust my butt in the mud 😜
dianne
Quote from: pinto_one on January 25, 2015, 07:11:24 PM
Well that is the passenger side, you could ask the seller a question on e-bay, see if he has the drivers side, if he does tell him to include it with the rest and its a deal, when the back yard drys out from all the rain I can go to my shed and take some photos for you, got one with the engine out and one with the engine in to give you a idea how they go, none of the 2.0 stuff will work, also maybe they can remove the front fenders and hood and paint them off, reinstall them after you have the engine up and running, do the a few times and it's hell on the paint, 😣
Thanks, sent it off. I'm sending the mechanics helper out tomorrow to see if he can find one. I need to have him pull the bottom radiator holder off a Mustang II. I just want my cars now :) LOL
Vehicles:
