Date: 02/27/2017 10:10 pm
Date: 08/30/2018 12:59 am
95 2.3l short block
Date: 03/18/2017 04:54 pm
79 pinto driveshaft
Date: 08/18/2018 02:03 pm
Date: 04/20/2017 10:10 am
Date: 11/05/2020 06:32 pm
Date: 10/28/2018 08:45 am
Bumpers
Date: 07/06/2018 04:47 pm
73 Caliper Retaining Key
Date: 10/28/2021 07:49 am
  • Online today: 132
  • Guests: 139
  • Total: 139
4 bolt vs 5 bolt front brakes
Started by mightyss1, January 25, 2015, 12:59:09 PM
Tonycando
Has any one made those adapters for the 71 72 drum brake spindle. I want bigger disk but really don't want to spring for the Wilwood kit u less I really have to.
OhSix9
don't bother with the stock 25 cent piece sized rotors.  order some 77 granada rotors for a 2 inch rotor upgrade 9 to 11  , pinto seals and bearings, a pair of say 80 camaro calipers and pads and a set of adapters from ebay or pretty much any rod shop on the planet.  (spindles are mIi, the worlds most used ifs in a rod)  Add in a pair of 4x4 blazer soft lines and assemble as normal.
Adapters
http://www.rjays.com/Brakes/MII_images/ALL42106.jpg
now,  If you really wanna go hard there is also a way using  60's 5 bolt drum brake hubs and then use the newer cobra or 05+ stang gt rotors n calipers.
Virgil to Sid
mightyss1
reevs, thnx for the offer, but too "nice" for my car..haha, going with speedway 5 lug "stock" rotors. dave 1987, i have a  1957 ... 9" rear . it had NO brakes when i bought it, so i got/installed a disc brake kit from summit. the front discs were "redrilled" 4 bolts that are real hinky. the plan...complete front end rebuild, new rack, v8 springs,etc...
I don't mean to hi-jack the thread, in any way. But...
Everyone always talks about swapping rotors for front brakes to get that 5 lug bolt pattern and strength, but what are you all doing for the rear? Drilling out axles/hubs for 5 lug, replacing axle shafts with 5 lug shafts?
I would think that if you are going through the trouble to re-do the rear axles for 5 lug and keep drums, you might as well make the change to rear disc brakes with 5 lug rotors and never worry about it again.
dianne
The Mustang II, even the Cobra and King Cobra had 4 bolts.
The Granada is a great swap set people use!
Vehicles:
- 1976 Mustang II mini-stock
- 1978 Mustang King Cobra II
- 1979 Ford Pinto Runabout
- 1986 Chevy K5 Blazer
- 1997 Suzuki Marauder
Not that I know of. Not stock. Even the V8 ones came with 4 lugs.
mightyss1
i know the pinto never had the 5 bolt setup, but how about the mustang II..?
