Date: 10/15/2017 10:03 am
Wanted 1973 Ford right fender
Date: 06/03/2017 08:50 pm
Date: 04/25/2017 12:17 pm
Date: 03/05/2017 03:27 pm
95 2.3l short block
Date: 03/18/2017 04:54 pm
Pinto Runabout wanted
Date: 06/05/2018 04:42 pm
Windshield
Date: 01/15/2022 09:31 pm
$300 Pinto for sale
Date: 04/19/2017 10:24 am
Date: 04/20/2017 10:10 am
  • Online today: 506
  • Guests: 401
  • Total: 401
valve cover gasket replaced and leaking
Started by ToniJ1960, January 06, 2015, 04:52:25 PM
ToniJ1960
 use the sealer only one one side of the gasket?
I glue em down with black silicon sealer. Just dont tighten them down too much. They dont need to be real tight...even hand tight will squeeze the gasket out and break it and cause it to leak.
ToniJ1960
 We used a fel pro vs50126c calve cover gasket. did not hammer down the bolt hole from underneath and used no rtv on the gasket either side.
Its leaking in front at the corner,running like a tiny stream and smoking real bad. A few drops on the ground. It might be dripping from around the arch in front but mostly it looks like its at the corner in front where it turns to go up.
Should I get a rubber one? Take it back off and use rt on the surface of the valve cover? I dont suppose its avoidable to remove it again?
Somewhere I read to use a ball pean hammer on the bolt holes from underneath to remove v around the bolt holes.
