Squire trim
Date: 03/28/2018 10:11 am
pinto for sale
Date: 09/11/2016 09:47 pm
pinto floor mats??
Date: 01/11/2017 07:27 am
Date: 10/25/2019 04:05 pm
1980 Pinto Wagon
Date: 02/29/2020 07:01 pm
1971 2.0 valve cover
Date: 01/25/2019 07:09 pm
Lower Alternator bracket
Date: 08/26/2017 05:11 pm
Clutch Fork
Date: 03/31/2018 09:12 pm
1980 Pinto Pony for sale
Date: 08/21/2021 03:54 pm
  • Online today: 506
  • Guests: 348
  • Total: 348
78 starter motor now
Started by ToniJ1960, December 04, 2014, 03:21:29 PM
jonz2pinto
If bad teeth on flex plate/flywheel just turn engine a little by hand and see if it engages.loose starter could mess teeth on flex/fly or on starter. if you have a extra set of eyes remove inspection plate/dust shield to have qiuick look.unplug coil first to avoid an accident if you try starter with someone looking while under vehicle. check cables also for loose connections.usually though bendix like out first if it is working.
Pinto-is short for pint-o-fun.
http://www.moddedmustangs.com/forums/5-0-mustangs/145886-starter-wire-issue.html
Go to post #14 and the pic there, look toward right hand side for part called 'starter drive', the bendix. On its' left side you can barely see a coil spring around the body, the spring gets weak and drive then begins to not engage and only whines. Worn teeth lead to the same.  Can replace one in starter in maybe five minutes once starter is off car. Provided of course you can get the part. I'd make a guess at $20 for part, I remember when they were like $6-$7.
ToniJ1960
 I bought this car when it was 8 years old and never had the starter or alternator changed so I guess it was due.
Is it possible the battery could be just a little weak? Maybe ill charge it up first.
In over 28 years the car only failed to start a few times.
Could be a loose starter too.
Starter bendix is dead or bad teeth on flywheel....................if you press hard enough at the parts store they should be able to supply you with just bendix alone and saves quite a bit. You may have to harass them though, they all want to sell complete starter now.
Assuming positive drive starter, if PMGR type then solenoid or throwout arm can be fudged too.
jonz2pinto
Sounds like the bendix is not kicking starter gear out to engage flywheel.sometimes  a starter will have a rubber plug on bendix cover.remove it and use something to push down on it before engaging starter motor.the access plug is rare,maybe just commercial trucks.I only seen two with in my life.also I have seen a little extra juice will help but not too often.
ToniJ1960
 Well when it rains :(
now the starter motor is gone out I guess. I started the car it died (cold) tried to start it again just got a whine. I tried again it started. Turned it off try to start it again just the whine again. Didnt turn the motor after the first time it whined so Im guessing its not the flywheel just the starter?
Lights dimmed some but I don think its the battery.
