1971 Pinto 5.0L
Date: 12/02/2017 12:23 am
1980 pinto wagon for sale
Date: 12/11/2017 12:13 am
Built 2.0
Date: 10/07/2018 05:27 pm
'80 Pinto Wagon
Date: 02/01/2018 05:20 pm
Date: 02/28/2024 02:07 pm
Date: 03/29/2019 07:20 am
2.3 front sump oil pan
Date: 02/19/2017 03:24 pm
Intake manifolds
Date: 03/06/2021 03:04 pm
1977 Left Side quarter panel
Date: 06/10/2019 04:16 pm
  • Online today: 506
  • Guests: 276
  • Total: 276
lower efi intake with carb questions
Started by waldo786, November 30, 2014, 04:41:18 PM
Most of the adapters out there are 1 inch tall, the lower works much better with 2 inch tall but most likely hood to air cleaner issues there.
I've got a 2 inch and the lower and it looks like it would work with no port work at all and the plenum is MUCH better shape and shared area. The porting becomes necessary with the lower restriction of air having to move too far sideways with no down drop and throttle butterflies are more in the way, why the porting lowers the entrance to runners a bit. Many people lower the 'x' in the middle to allow for the mentioned problem. That though creates issue with the outboard cylinders then, mixture hits a flat when the down-to-sideways curve at top into the 1 and 4 is partly/mostly removed doing that porting. You need that radius there and the extra plenum to allow for better part throttle power. The 'x' in the center is narrowed to help make up for the butterflies being too low because of the 1 inch adapter, 2 inch doesn't need it, much cleaner drop there like a well done tunnel ram, basically, five minutes of porting to radius the holes there all that's needed or even nothing, the taller adapter allows that. The splay outward to runners is much improved with taller adapter and the distribution will be as well too. The hood issue though is more important to many, hard to get a air cleaner that clears with that last inch.
Think how many V8s pick up a solid 10-15 hp. when simply throwing on a 1 inch spacer between carb and manifold, it does the same thing.............more room to make the turn at entry to the runner and motors generally like that a lot. Carb butterflies extending down into active switching/intermixing areas of the plenum often rob power, get them up just a bit higher and free power for the taking almost.
waldo786
I know some people are using this setup on their cars with the ACE adapter that is available.  My question is do you have to do any modifications to this manifold (someone mentioned porting), or can you simply bolt on the manifold to the head, bolt the adapter and carb to the manifold and be ready to go?  If anyone is running this, how do you like this setup compared to a stock setup?  I'm trying to decide whether I'm going to switch to this or just put an autolite 2100 on my stock intake.
