Rear Bumper
Date: 07/26/2021 01:08 pm
Date: 02/21/2017 06:29 am
pinto floor mats??
Date: 01/11/2017 07:27 am
Date: 11/12/2020 08:28 pm
Date: 10/27/2018 03:30 pm
1980 Pinto-Shay for sale
Date: 07/07/2016 01:21 pm
Date: 09/15/2019 12:28 pm
Date: 08/30/2018 12:59 am
1976-1980 A/C condensor
Date: 09/21/2020 10:43 pm
  • Online today: 506
  • Guests: 392
  • Total: 392
Mustang II Rear end question
Started by biggrgivens, November 29, 2014, 12:27:48 AM
biggrgivens
Thanks! I am planning on building a 75 turbo runabout similar to my 72, so prepping for an easier route.
74/80 Pinto backing plates / drums are the same as any Mustang II. This was done so Ford could use up what they (6 3/4") already had in stock. The Mustang II 8" rear end is a odd one. Center section (gears) are all the same in any 8" rear end. Some but not all of the axles will fit with a little work (shorting). The axle bearings are a one of a kind to only a Mustang II. The axle bearing retainer is different from any other 8" rear end and is MUCH shorter than any other 8". Put the long one on the axle and the axle will not go all the way into the housing.  The Mustang II rear end is a direct replacement in any Pinto. Had them in my 72 and two 80's Pintos. Drive shafts for a 6 3/4" will work just fine with a 8". Been there and done that.
The 71-73 Pinto's have a smaller hub than the 74-80 Pinto's and the Mustang II's.  So your early small hub drums probably will not fit on the larger Mustang II axle hubs.  When I put a Mustang II rear in my 71 Pinto, I used the Mustang II brakes.  You get a little wider brake shoes and wider drums with cooling fins.
biggrgivens
Can I reuse my pinto brake backplates and drums on the mustang II rear end housing? Is it just a matter of swapping the pinto brake setup mustang II rear end and axle. ( I know axles have to come out to put backplates on .)
