Date: 07/17/2018 09:22 pm
13" Style Steel Trim Rings
Date: 10/09/2020 10:35 pm
78 pinto wagon
Date: 03/03/2020 01:07 pm
1979 hatch needed
Date: 05/13/2018 08:52 pm
Date: 06/19/2018 03:58 pm
2.3 pinto carb
Date: 08/18/2018 02:07 pm
Date: 09/03/2018 08:58 am
Pinto wagon Parts
Date: 06/23/2021 03:25 pm
1973 Pangra
Date: 01/06/2015 02:19 pm
  • Online today: 506
  • Guests: 310
  • Total: 310
ID the dash dimmer wire
Started by 78_starsky, November 23, 2014, 10:44:16 AM
78_starsky
that would have worked nicely too.  i should have done it that way, wasn't into pulling the dash apart today.   the car doesn't get driven much during the nights in summer anyway...  so it will be ok for now   :)
thanks
76hotrodpinto
I like to tap into the instrument light dimmer wire, just off the switch. Then you can dim your auxiliary gauges with the panel light dimmer control.
78_starsky
thanks slow,    traced it back and spliced at the fuse box.
slowride
Typically Ford makes the gauge lighting circuit blue or blue/black tracer. Easiest place to tap in is at the audio connector, but it's cleaner at the cluster connector.
78_starsky
hey all,
i need to splice into the dash/cluster dimmer light wire, (finally want to light up my gauges). placed in a new vac gauge yesterday, and decided that it is time to finish wiring it all up.   looked through my books but couldn't fully get a grip on what the wire colour code is, or best place ti splice in.
thanks
