Date: 07/20/2017 01:23 am
Custom Pinto Project
Date: 06/12/2016 07:37 pm
Date: 04/20/2017 08:56 pm
Need 72 pinto parts!
Date: 06/14/2019 01:40 pm
pinto wagon parts
Date: 12/19/2019 01:43 pm
Date: 11/08/2019 10:01 am
Wheels and Parts
Date: 07/06/2018 04:50 pm
Date: 02/28/2018 09:37 am
Parts Parts Parts
Date: 09/08/2018 03:13 pm
  • Online today: 506
  • Guests: 181
  • Total: 181
Holly 2300 series 2 bbl carb. on a 74 pinto 2000cc
Started by kartracer28, October 27, 2014, 12:15:11 PM
kartracer28
Yes 100% sure its a 2.0 its one of the "early" 74's I wish it was the 2.3.
Yes and yes. The stock power valve circuit will feed too much fuel, it needs to be restricted down to like .020" holes each side.
FYI, old American Motors 2 bbl. carb adapters that used to be part of every 2 bbl. manifold make good adapters, the smaller inside hole pattern fits the small pattern on the 2.0 manifold.
Sure you got a 2.0? '74 came with 2.3................
kartracer28
 I would like to put a "better" carb on my  74 Pinto. will the Holley 2300 series 350 CFM 2BBL  be a good replacement carb. The motor is stock except for an Eslinger  header and 2  1/2" exhaust and Pertronix ignition. Will I need a  "adapter plate" for the carb?
