Date: 01/06/2017 11:42 pm
Wanted 73 pinto squire wagon
Date: 05/09/2020 11:59 am
1978 Squire wagon 6 Cly
Date: 03/08/2021 10:44 am
Date: 10/28/2018 08:45 am
sport steering wheeel
Date: 10/01/2020 10:58 pm
1977 Pinto for parts
Date: 10/10/2018 06:25 pm
1973 Pinto Wagon
Date: 05/06/2022 05:13 pm
Crankshaft Pulley
Date: 10/01/2018 05:00 pm
1970-1973 Gas Tank/Blue Dash
Date: 02/07/2019 11:57 pm
  • Online today: 506
  • Guests: 178
  • Total: 178
clicking noise in my rear end...
Started by pinto bismol, October 06, 2014, 05:00:46 PM
pinto bismol
FIXED!
U-joints. Thanks for the input everyone!
Caution.....explosive personality!
Quote from: blupinto on October 11, 2014, 10:27:24 PM
Possibly speedometer cable or differential needs oil?
I've had a clicking speedo cable before but my needle would move slightly with the tick tick.
pinto bismol
Topped off the differential yesterday. Took less than half a quart.
Bought some new u-joints and will attempt to install them this weekend.
Quote from: pinto bismol on October 08, 2014, 03:55:58 PM
only happens during acceleration....not braking. even goes away when coasting, but when i push the gas, here come da chirp!
Check for something rubbing against the driveshaft or a wheel/tire/brake
pinto bismol
If just doing it at braking then can simply be dry contact spots on the backing plate. Brake assembly begins to swing out of concentric from wear and then the oscillation wipes backing plate dry and then begins to click as shoes touch/untouch.
Check the emergency brake cables to see if they are rubbing & jack it up & rotate the tires by hand to be sure it's not a brake part making noise. A bolt stuck in a tire will make a ticking too.
You probably don't have p-trac there and p-trac will make noise like that on turns first. The spider gears pretty much don't spin going dead straight unless you have oddball tire sizes on both sides to differ greatly.
If u-joint then it will be fairly high frequency to match the u-joint spinning which is faster than rear axles turn.  If slower then look for something as simple as a rock stuck good in the tread, that can do it.
pinto bismol
what should be in there? it's a 2.3 automatic 1976.
also, I haven't changed/added anything to it.
pinto bismol
no jokes please!
I hear a clicking noise when I accelerate. Sounds like a playing card in a bike spoke. Just started a few days ago. Nothing dragging rubbing or loose that I can find. Any ideas?
Thanks!
