74 pinto
Date: 09/11/2016 06:32 pm
Date: 02/25/2017 08:45 pm
Date: 08/08/2017 01:44 pm
Date: 06/07/2021 08:14 pm
Date: 12/30/2022 01:30 pm
pinto wagon parts
Date: 12/19/2019 01:43 pm
Interior Parts
Date: 08/07/2017 03:59 pm
Date: 02/18/2017 05:55 pm
Pinto Vinyl Top
Date: 10/09/2020 10:29 pm
  • Total Topics: 16,268
  • Online today: 177
  • Guests: 190
  • Total: 190
going from a 2.0 4 spd to a T 2.3/T5 List of parts?
Started by Sir Thomas Crapper, September 25, 2014, 08:55:11 AM
There is not a parts list per say, but I did a write up on my conversion.  You should be able to glean most from it:
http://www.fordpinto.com/general-pinto-talk/so-you-want-to-build-a-turbo-pinto-part-1/msg76893/#msg76893
http://www.fordpinto.com/general-pinto-talk/so-you-want-to-build-a-turbo-pinto-part-2/msg76894/?topicseen#msg76894
Bill, who goes by "JoeBob" did one also. And there are currently a number of people in progress who are reporting on theirs. "65ShelbyClone" being one of them.
I assume with the 2.0 you have an early, thin bumper car? My article should help as it is based on a '73 conversion. If you have a '74 2.0 then there are some modification that you don't have to do since the 2.3 was an engine choice in '74 and up.
Sir Thomas Crapper
Is there a list of what is needed to do the swap?  Will the pinto 2.3 motor mounts work for this?  I picked up a 2.3 oil pan and pump, is this necessary to change over?
I remember reading that a stock fox body mustang driveshaft is the right length, but you need to install a new rear u joint.
Are there any links to builds?
