1980 Pinto taillights
Date: 12/26/2017 03:48 pm
Clutch Fork
Date: 03/31/2018 09:12 pm
pinto floor mats??
Date: 01/11/2017 07:27 am
71-71 speedo cable
Date: 07/31/2021 09:04 pm
76 Pinto Wagon
Date: 07/08/2020 05:44 pm
1974 Ford Pinto
Date: 10/16/2017 10:45 am
Date: 01/06/2017 11:42 pm
Lower Alternator bracket
Date: 08/26/2017 05:11 pm
Date: 08/03/2018 09:19 am
  • Online today: 2,457
  • Guests: 534
  • Total: 534
manual transmission and diferential type of oil to use
Started by dag, September 23, 2014, 10:17:08 PM
With Redline MTL, the stock 4 speed will shift like it got hot butter for lube. If you want to try different lubes, do like I did and put a drain plug on the bottom of the tranie at its lowest point. You can even do it with the tranie in the car if you start out with a small drill, and a big drain pan. I taped mine to 1/2-20 as a lot of drain plugs are that size.
I'd use that in the rear, might make shifting stiff in the cold in MTX.
Would work fine, I'd lean more to 90 or even plus a bit on diff.
AndrewG
Quote from: amc49 on September 24, 2014, 07:20:06 PM
70-80-90 weight gear oil should work in either one, lean toward 90 on the rear diff.
What about the use of synthetic in these trannys.  Do you have recommendations?
dag
can someone tell me what kind of oil should I use in a 1972 pinto manual transmission and what kind (if different) should i use in the rear end.
