Date: 01/10/2022 03:41 pm
76 Pinto Wagon
Date: 07/08/2020 05:44 pm
Pangra wanted
Date: 02/05/2017 01:58 pm
Date: 01/24/2021 07:54 pm
Lower Alternator bracket
Date: 08/26/2017 05:11 pm
Racing seats
Date: 10/24/2019 09:41 pm
Mustang II C4 Transmission
Date: 07/28/2017 06:26 am
Date: 03/15/2023 02:16 pm
Date: 09/20/2018 11:01 pm
  • Online today: 506
  • Guests: 223
  • Total: 223
blow by
Started by bad bean, September 21, 2014, 10:51:08 PM
Easy way to fix it will be sealing up the motor the best you can, then running a hose from the valve cover to the air cleaner. Use car lots have been doing this fix since Henry Ford was a pup. If you use a piece of water hose, paint it black so it doesn't show so bad. Sucking the blow by down the carb will work great for a while. After that your on your on. Look on the Vega web sites as they had lots of blow by and blow ups as one will follow the other.
Exhaust evap only works at higher rpm, why it must be combined with intake evap to work. A pcv system is NOT intake evap, the motor must be sealed specifically for it.
Moly rings mount correctly as far as side facing up like every other ring, rings are designed to twist upward or downward depending on the design and backward makes for a bad problem. You make all ring manufacturing marks face upward at rebuild time. A few are not marked and a problem there, most are though, as it is in makers best interest to do so or risk bad press about quality of product. Only oil ring pretty much doesn't matter but even some of them do now.
You are trying to mask an engine problem with fixes that are not going to work, you fix the basic engine there. Brand new rebuild already blowing by a lot is not going to get better. Do you have oil baffle before the pcv as OEM? If the pcv just pulling off anywhere could be a problem. Pcv entry is always baffled to the max.
bad bean
No not yet it has pcv and valve cover breather right now,pcv connected to carb plate.was thinking that putting a evac system on to help with blow by.
Wait, is your crankcase ventilation system connected to the collector evacuation fittings?
Turbo mufflers are not the best-flowing designs out there, so it's possible that exhaust is pressurizing the crankcase.
bad bean
I don't think ring installed wrong they are Molly rings.what are thoughts on evac system car has thrust turbo mufflers.I read that you should not run mufflers. Collectors have fittings for evac.
I'd run the engine with as many openings as you can get for the crankcase ventilation (filler cap off, PCV plugged at the intake, but open to the atmosphere etc.) . If, after that you have the problem I'd be concern the rings got installed backwards.  Is it possible the PCV is installed backwards? Thread ins are difficult to get wrong, but some of the slip in type are similar on each side.  I've also heard of rags etc. to keep debris out during assembly being left behind in the head drain back holes.  While not your problem I've heard of wood blocks used to prevent crank rotation during assembly being left behind. So, don't discount anything from happening.
Years ago I had an early 80's Honda Civic with the CVCC engine. By 100K miles it was getting 50 miles to a quart of oil.  Strangely it never really smoked nor leaked.  I honed the cylinders and put new rings in it (A poor man's rebuild).  That motor smoked like crazy for the first few hundred miles and I never got better than 500 miles to the quart.  I'm 99% sure the rings got installed backwards. There were no instructions with the ring set and I was dependent upon the kid at the store for directions as Al Gore had yet to invent the internet - enough said.
Uh, if block honed correctly for ring type then any ring seal pretty much mostly done in the first 30 minutes of engine running. A bit more will occur over time but really very little. Most happens in the first 5 minutes. If any rings installed upside down forget it, not going to happen. Same if block was worn and no hone or a simple 'glaze-breaker', sometimes it can work but if top of block worn deeply from top ring land the hone job will not touch that. Time to bore.
Put more breather on it.................
bad bean
Yes new pcv, drive it around getting out kinks. Saw that valve cover had pushed gasket out in one spot. What is best way to get rings to seal faster. Don't want to blow out rear seal.
Do you have a PCV system hooked up? Sometimes aftermarket valve covers will be installed without openings for crankcase ventilation.  If the rings were installed backwards they will not seal correctly.  Lastly, until the rings are broken in (assuming correct installation and a PCV system) you may get added crankcase pressure.
bad bean
 :'fresh rebuild on sbf motor v-8 conversion having blow by issues pushing oil out different places.does anyone have any advise.
