Electrical
Date: 03/29/2017 11:37 am
Date: 06/05/2018 09:13 pm
Date: 08/26/2018 06:35 pm
Date: 02/16/2019 10:46 am
1972 pinto grill
Date: 02/27/2018 12:13 am
Date: 06/28/2019 09:14 pm
77-78 front grill
Date: 04/07/2017 12:35 am
Racing seats
Date: 10/24/2019 09:41 pm
Rally spoiler wanted
Date: 05/04/2017 01:32 pm
  • Online today: 506
  • Guests: 225
  • Total: 225
blow by
Started by bad bean, September 21, 2014, 10:51:08 PM
WAS ENGINE BORED FOR OVERSIZE PISTONS??? Then MUST have been honed or totally messed up there. You CANNOT competently assemble motors and not know if hone done/not done if rings are changed, death lies there and totally unacceptable. The start of a major FU. Not trying to be an butt or insult anyone, but it needs to be said. I would be dogging the person who did the machine work there for more information. If not bored at all then you get into the nightmare of what kind of condition the cylinder walls were in to begin with, not knowing if honed just doubles that nightmare with all kinds of bad possibility. The rings (especially moly, even worse if double moly) MUST have correct break-in wall finish or they are junk as soon as started up and run five minutes. You don't get another chance after that without new rings/walls.
There will be no exact compression number since cam timing alone advance/retard can greatly affect that, all I know is true 12/1 needs well over 200 psi, I'd be expecting like 220-230+ on a well sealed motor. Even more (250+) if the motor truly setup to get the advertised compression, i.e., decked correct for the application and proper cc head/head gasket thickness, the compression can range off a full point by simply throwing in pistons that say they are this or that number, not nearly that simple. Catalog advertised compression numbers are worthless without the motor set up to spec called for there.
Different type rings require different hone machinist should have asked what rings you were using?, if water was 240 cylinder walls were hotter, a comp test should tell.
bad bean
No certain hone done. Motor did get warm during break in 240 degrees, fan had quit for some odd reason.
Was the cylinders honed for the particular ring type??, maybe cylinders got a little hot on break in and some rings distorted seen that a few times..
bad bean
The rings are 1/16,1/16,1/8.:-hydraulic lifters.I did not check piston to wall.something that might be my problem.would I not hear some skirt .slapping.maybe not .
bad bean
Motor work done by others, I put it together. I am not professional builder but have put many motors together. Ring gap is 18-20.I put rings at top and second are over pin 180 from each other oil ring is at 11 and 7 o'clock. Motor runs good plugs a little sutty but that could be cold plugs or only driveway running. I have only drove it around the block. It's not tagged yet to really put time on motor but won't to get bugs out first. Someone said to run and put rubber glove at pcv. Haven't done that yet. Still not sure if gauge was wrong will do test again to be sure. Just hoping to find solution without having to year it down. Not sure if I'll have time if can't find problem. Thanks guys looking for any input.
Testing it at operating temp isn't going to tell you anything new.
bad bean
Should I run motor till 180 degrees, going to pull several test checking o ring. How much psi with 284/544 110 lobe separation.
Did you try a wet compression test too? Add about a teaspoon of oil to the cylinder and if compression comes up substantially, then ring seal is a problem.
I would expect to see at least 180psi with your build, cold or not.
For sure I would use a screw in gauge. They typically have a hose. I position the hose in a way I can see the gauge when cranking. Depending on the engine it takes 3-6 revolutions to get a full compression reading. Watch the gauge and see when it stops rising. It won't go higher.  Get the right gauge (if you haven't already) and do the test again.
Assuming the rings are the issue, it would seem that the plugs would show evidence of oil fouling or contamination.  And I guess this is what is baffling.  You have very low compression, but no smoking.   You have evidence of seals and gaskets weeping, but can't detect an abundance of crank case pressure unless you "get on it."
  Did you build the engine yourself,  or did someone build it for you. If you built it, what is you background and experience? What grit did you use for the wall finish? Was a hone plate used. What was the piston to wall clearance. I'm assuming forged pistons - they require more clearance that need to be warm to work properly. What is the ring width and end gap?  This would all be helpful to to getting to the bottom of the problem.
If it is truly a blow by issue then something is wrong with: Piston to wall clearance, piston rings - upside down, or broken, wall finish that damaged the rings.
If it is simply a crankcase pressure issue then somewhere the engine is not venting the crankcase properly.  A thought comes to mind.  What are the valve clearances (or are they hydraulic)?  I've heard of improperly set valves that never seat and the potential exists that pressure (possibly) could be going up the valve stems.
It very easily can be. The gauges and getting them to seal properly to get repeat numbers over and over can be problematic, why you always pull multiple tests. Numbers varying are an indicator of doing something wrong. Done right the numbers will fall in line pretty much. You crank until gauge quits moving on every cylinder, not a certain number of spins on each. Lower reading cylinders take more spinning but the numbers will still not come up, telling you something wrong. You repeat to verify it. I even go so far as to tear down the setup, i.e., unscrew the gauge and then screw it back in again, the sealing o-ring sometimes does not seal, a repeat can show you that as well. I keep extra o-rings on hand, they tear up easy doing that.
bad bean
Just realized that motor has to be at 180 or above correct not just run for a few moments maybe the person doing test is problem.c guess that was my problem.
Motor is dead, engines with less than 100 psi will never run correctly, not enough heat (from compression) generated to keep plugs running clean. The limit we used when I built engines was 100 psi, you need well over 200 if cam timing like said and 12/1 compression. Afraid you got a serious issue there.
Forget the d-mn car for a bit if facing heart surgery, or at least let what will be be, it ain't worth the extra stress I'm tellin' ya. I had double bypass and did that, you gotta give it all up to realign your head for it. Enjoy working on the car, not turn it into a millstone.
Assuming you did compression test correctly..........warm engine and throttle held wide open while spinning engine with ALL plugs out of it and using a decent screw-in gauge, crap push-in compression gauges cause a LOT of unnecessary trouble. Do more than one spin on each cylinder as backup, I usually do at least three.
A small possibility that you have washed cylinder walls down enough with raw fuel to kill compression, I've heard of it but don't necessarily buy the idea. My view is that if oil cut back that much the engine will scar the walls anyway to make permanent damage. I've heard other skilled guys talk of it though, that the engine can lose almost all compression to then get it back later and run fine, the part I have trouble with but you never know.......................
bad bean
Just a update on motor build.to start eagle crank and rods,trw piston, comp cam hydraulic flat tapper 284/544, comp valve springs, comp lifters, aluminum heads 205/160 ss valves, parker funnel web intake 7.5"tall Holley carb 650 double pumper.motor break in normal run time 20 minutes@2500rpms.no leaks at driveway running.only when getting it out on
Is there any possibility that gas worked its way into the crankcase at some point and then ignited causing a spike of pressure that caused the seals and gaskets to leak?  Once I did a compression check with the plugs out and the wires dangling. The car was jacked in the front and that caused the float bowls to over run. Gas ran past the rings and accumulated in the crankcase - as well as shooting out the spark plug hole.
At some point the dangling wire lit the external fuel in a WOOF! And about a second later BANG!!! The crank case vapor went off. I had the valve covers just placed, but not bolted. Everything flew and it was all quite startling.
bad bean
Motor not smoking. pulling this motor is going to be frustrating.things not going well, waiting on heart transplant and building motor has me sick at the stomach.
bad bean
Cam is 240/246@.50 110 lobe separation.one cylinder was at 75 psi.not sure if gauge was any good AutoZone rental.when running just pulling the pcv out of cover it has a slight pump of air just enough to feel.you made mention of head gasket.not getting oil in water, water in oil or plug Fouling with oil or water.having one heck of time with this build.
Not sure what you should be seeing given your cam, but that "seems" low. Is your 284 duration gross or @ .050?  In a gas powered engine there is a limit to cylinder pressure. As you get a cam with more duration you both increase overlap (typically - but not always) and have valve events occurring earlier.  All that tends to lower cylinder pressure hence the need to increase the compression ratio to compensate.  How much pressure you get at cranking speeds as opposed to operating speeds could also factor in.  I assume they are all at 90PSI? That kind of rules out a damaged head gasket leaking into the intake valley.  You speak of leaking seals and gaskets..., is there smoke too?
I've never built engines such as yours. Hopefully AMC49 or others with this type experience will chime in.  But, if you want my guess I'm still thinking rings.  All the air should enter and exit the manifolds, not wind up in the crank case. The only other option would seem to be a clogged exhaust system and lots of exhaust valve stem clearance.
Do you see the actual pressure, or only the results of it. Remove the PCV hose, but make sure it is still attached to the valve cover, crankcase or wherever you have the other end of the hose attached. Hold a rubber glove around the hose and run the engine. Use care because it might rupture.  Report back what happened to the glove and how fast.
Way low.
Pull it & tear it down before you damage it beyond repair.
Gaskets are cheap.
bad bean
Checked compression psi not sure but 90 psi was what it read.that seems light for that motor unless rings are not seating.not sure that it's not leaking at the valve and could that cause the blow by.just stumped at this point.
bad bean
Info on motor so we all have the same thoughts.306ci, 12.1 piston,284/544cam,aluminium heads with 205/160,parker funnel web intake, Holley 650 double pumper.trans with 3500 stall, reared 5.38 gears.thrust turbo mufflers 2 ft off collector.I'm going to do compression check to see if all's well on that end.Will report findings.just didn't want to rebuild again.car only going to run to some shows and strip few times.guys I want to thank you for things I'm learning here.just looking for way out before rebuild on fresh motor.
...Or broken piston rings on install. Do a compression test (or leak down test if you have that available) and report back.
Crankcase evacuation will not work. It has to have a sealed up engines with reversed seals, I also ran no valve stem seals at all on mine as you stick the valves in the guides when it works right. Exhaust alone won't get it there, the exhaust has too little effect and only works past about 3K rpm. There is ZERO evac below that. You balance the no exhaust flow with intake too, the intake covers low rpm and exhaust takes up when the intake vacuum drops. Only works though with crank end seals reversed, they leak like hell in normal position since they were made to seal pressure not suction like that. Under suction it's like no seal there at all. Full evac like that demands short exhaust system, almost impossible to do it with full to rear of car exhaust, the stackup of gases stops the venturi effect in pipe. It works best on open header but I drove street cars around with it and simple header mufflers only and was able to keep crankcase at around 10-15 inched Hg most of the time. Everything's gotta be perfect to do it though.
What else could be pumping air? Dead cylinder walls passing lots of gases around side of piston. Hole melted or punched in piston from detonation if ran pump gas with 12/1 compression, impossible, the motor will last five minutes like that.
bad bean
That is my issue, I did pull breather and pcv couldn't tell if pumping air. Oil was hitting header so smoke was coming off them. I'm looking to run evac system instead of pcv.I read that mufflers create problem. They are thrust turbo. Will installing evac not help to stop crank pressure or reduce it as well as sealing rings against wall.
For all the wonders of the Internet sometimes there are things that are hard to find pictures of, and valve cover baffles seem to be one of them. Here is an article that shows baffles that have been cut down, so it will take some creative thinking to imagine what they originally looked like. http://forums.vintage-mustang.com/vintage-mustang-forum/509142-build-your-own-valve-cover-baffle.html
To some degree this post seems to be running off track. Your issue is crankcase pressure that is weeping oil at the gaskets and seals - correct?  If your PCV system was sucking oil up directly (yes, that would increase crank case pressure) but you would also be pumping oil into the intake and fowling plugs severely.  And, I didn't read that as your problem.
As I said above run the engine with as many openings as you can. PCV hose removed, filler cap removed (sorry, it can get messy) and see if there is excessive pressure coming out. If there is then I'd still have to say it is a ring issue. I say that because what else would be pumping air???
bad bean
Valve covers don't have that for pcv or breather. What is a way to correct it or just buy new covers.
The valve cover will have a baffle (usually a piece of metal, sometimes stuffed with a steel wool like substance). The purpose is to prevent direct oil splashing of a PCV that sits in the valve cover. Sometimes they are removed for rocker arm clearance.
bad bean
Not sure about the baffle can you give me little more info. Guess I'm not that smart about baffles :-*
You cannot run pcv straight out of engine unbaffled if it is in an oiled spot, it will blow oil right into intake. The baffle is usually at/under the pcv takeoff point wherever it may be as long as the OEM point.
Bevel on ring CAN go on the bottom side if a reverse torsional twist ring...........but usually those are on second ring. The dot is the thing there. Or a letter or somesuch.
Moly rings need to finish block with a fairly fine hone finish, too rough will eat the moly out almost instantly. Bore quality figures in there greatly too, it is getting so hard to find competent people to run boring bars any more. Here in north Texas they used to be coming out my ears, now I'd be terrified if I had to get it done. Last two I had done were both messed up by those who talked a whole lot more than they worked and high dollar shops with big reps too.
bad bean
Rings had bevel on top ring and second ring had dot.Not trying to mask just looking for advice before having to tear it down. Pcv is just hose from carb to pcv no baffle. I'm running high compression about 12.1, cam is 284/544 hydraulic flat. Intake is Parker funnel web.
