Clutch pedal needed
Date: 01/11/2024 06:31 am
72 Pinto parts
Date: 11/14/2019 10:46 pm
ENGINE COMPLETE 1971 PINTO
Date: 12/28/2017 03:55 pm
2.3 front sump oil pan
Date: 02/19/2017 03:24 pm
Date: 12/31/2017 11:14 pm
Date: 11/23/2017 05:44 pm
Interior Parts
Date: 08/07/2017 03:59 pm
Date: 10/10/2019 09:42 pm
Mirror
Date: 04/15/2020 01:42 pm
  • Online today: 506
  • Guests: 242
  • Total: 242
blow by
Started by bad bean, September 21, 2014, 10:51:08 PM
bad bean
All that was checked.valve guides cut, spring heights all within.010+ or-, no coil binding.pvt checked.I knew it was rings .til today's leak down i was looking upper end.now I have another question what should my timing be set at with accel dual points distributor mechanical advance no vacuum.looking for idle timing and max timing at what rpms.cam as stated 284/544.just want it to sound it's best while I'm trying to sell it
Luck buddy, sorry to seem to bring you down and certainly not intentional, just better to hear it like it is rather than smoke.
If no one ever clearanced valve guides/springs/retainers for lift could easily be upstairs as in cracked guide, or maybe a serious seat leak. If valve to piston not correct maybe bent valve. You got big enough cam there all of that should have been checked 100%.
bad bean
Littleton Colorado craigslist.
Well, it has been a tough journey. From building this car for car shows and drags, to having the crankcase pressure issues, to finding out you need a heart transplant, to finding the rings are bad, to attempting to sell the car at an obvious lose.  That is a lot to deal with in a few short weeks!
Everything happens for a reason. So, all I can offer is to try and see the ultimate good that can come out of this. And, hopefully there are brighter days ahead after the important things are completed.
BTW, post the CL link here (I couldn't find it) and perhaps those here can direct a buyer to you. If you going to sell a Pinto, then Pinto owners are probably the most likely source of finding you a buyer.
bad bean
Did another compression test as follows:
#1@160 #2@145 #3@140 #4@155 #5@145 #6@130 #7@150 #8@145.
I completed the leak down test.as expected ring problem all cylinders were at 10-15% but number 6& 8 was at 40% you could here it pushing out valve cover.don't think ring upside down just not seating.or something else.where's overhauling at when you need them.only problem with selling now no one is buying.I have it on cl now, people want to trade don't need trades.
The car does not care would be my thoughts there..........yes the density difference would drop the number some. All this casting about should clearly show you are not going to get a one size fits all clear cut answer there. Any of the things mentioned are going to affect it. I get in the 160s on 7/1 two stroke engines all day long, would still be like 130 at that altitude.  Anything I've ever built with like 12/1 went way over 200 psi or something was wrong with it. There have been a bunch of those, we built plenty of bracket race engines of all types at our family shop. 200 psi sea level adjusted for 20% off at 1 mile up still is 160. I'm at about 500-550 foot here.
My view here would be play stupid, fix the breather issue and sell the car while still together and you around if truly looking to help the significant other.
bad bean
Something else that might be of interest on psi.I'm at 5400 ft in altitude.a site I was just reading say 150 psi at sea level will only be 120 at 6000 ft.what are thoughts on that.
bad bean
Yes I'm looking for that cure all than having to pull motor. Yes my time is short due to needing a heart transplant. But how many of you have looked for outs. God willing I'll be here for some time but a car in pieces doesn't sell to well. If something did happened. My wife would get taken advantage by scums looking to get something for nothing. If pulling motor is so easy come get you some.
Moly rings will seat well before the cam is broke in. That's one reason we use them. What do the other sites say is wrong with the motor? Maybe its time to get an experience engine builder to take a look. Everyone knows a really good dirt/drag racer. Find one and pay him if necessary. It may very well be your cheapest way out. And just remember that two many cooks spoil the pot.
I think what it is, is that he is hopeful that the problem will be something that  doesn't require opening the engine - or is corrective with alternative devices.  Thus there is an attempt to attribute the problem to cam overlap, need of an exhaust evac-system, low quality compression gauges etc..
I can understand that. He stated he has health (heart) issues.  I'd hate to have put an engine together only to have to tear it down shortly afterwards.  On the other hand I agree that it most likely is rings and that will require opening the engine. I see the leak down test that is supposedly coming as the final answer.  If that shows that the compression gauges were accurate then I don't think there is any question.  So, I see a finality coming shortly - one way or the other.
Update - Try running the engine longer and see if the compression comes up.  Even if not to optimal at least a notable increase.  It would support the theory of the rings not yet seated. Maybe it will take more time (though unusual).  I remember once my wife took a pregnancy test and commented that she was SO pregnant that the test stick was completely colored immediately.  I then read the instructions (isn't that a role reversal) and noted that you are not suppose to read the test for 10 minutes.  By that time we were no longer expecting.
bad bean
I'm not denying that there is blow by from rings. And that oil is getting by some seals. Other sites have stated that motors can go many miles before rings seal. I'm not saying many thousands just hundreds of miles. Since motor only has maybe 1hr run time. I know that people on this site say it should happen quickly. With test for leak down will let me know where from. Not sure but some sites say that cylinder pressure of 180 gives you over 12.1 compression.
You're doing the same thing all over again, asking about overlap (but no mention of how much) but only half-framing the question setup........seems to me some of your grief is self induced by vague questions with no information to frame any possible answer that makes sense, and then answer not liked. You give incompletely, you get back incomplete.
Looking at overlap is looking at the issue backwards, the compression effect is from intake closing point not opening point, just that the two are linked mechanically since cam is not DOHC.
I built a 304 AMC using 8.5/1 pistons and heavy chamber work with biggest hydro stick (IIRC 234I-244E @ .050", .550" lift) I could find and still had 140 psi with maybe true 8/1 compression.
BBC with true adjusted 12.5/1 and huge overlap roller and 300psi.
You are not going to make up for that huge difference with overlap alone. Overlap has nothing to do with the OP blowing out of seals either. That is from leak across the rings, the engine is an air pump and will pump up the crankcase as fast as the cylinder if leaking.
Quote from: dick1172762 on October 01, 2014, 10:33:26 AM
      I don't want to stop reading this post because its like a good story, but we can't turn to the last page to see the outcome. I've learned all kinds of good stuff on here, buts its all coming from other people. Ever possible thing that could be wrong has been talked about over and over and all say to pull it out. Sorry if you don't like that idea but it will happen sooner or later.
That is likely the case, but since he now has access to a leak down tester I think there is one last thing to see here. You know, kind of like the doctor sees the X-Ray, then a CAT Scan, then (and where we are at now) a MRI.
  Stranger things happen. My daily drive (Mazda Protege) was throwing P-300 codes (Multiple Random Misfire).  Couldn't figure out why.  And, it often happened when the A/C was on. I attributed it to the A/C clutch engaging, - and momentarily slowing the engine.  This went on for about 6 months. The car developed a slight tick sound at idle (only). I looked everywhere and could not find the source. Eventually the tick took on every aspect of a rod knock.  Eventually I found the problem.  A loose balancer that was spinning fore/aft on the crank shaft within the key clearance (that was increasing constantly). This was throwing off the Crank Position Sensor  The bolt was "stiff" in the treads and thus felt tight so I assumed the balancer was tight.  So, sometimes disastrous symptoms  (rod knock sound) have simple solutions (tight the balancer bolt).
Quote from: bad bean on September 30, 2014, 06:22:53 PM
Last I checked didn't ask anyone in particular to put there two cents in. If you don't want to answer stop reading. I just needed help not smart @$$. Must be wrong site to seek help.
Well good luck, hope it's an easy fix.
bad bean
Borrowing one from friend he said to do leak down as well.had someone else say same thing in earlier post.didn't have one til now this will let me know where problem is upper or bottom would much rather find problem on top than bottom removing head is nothing compared to doing while motor.
Should do a leak down on it..
bad bean
Thanks thats all I'm asking. They are rental gauges not a good gauge. But that's all I have for now. Pistons are rated 12.1.I think I'm at 10.5-11 according to sites when I enter specs. How much do you know about over lapping and could that cause low psi.
125 lbs too low for 12:1 comp.
My B2 engine (that was returned ready to blow up - long story) had 10.35:1 pistons & had 170 lbs.
Try another gage. Some oil in each cyl.
As I mentioned, gaskets are cheap. If I were you I'd pull it & do a detailed inspection (after trying another gage).
bad bean
Well sooner or later you've got to live with it or pull it out and fix it right. In the old days with chrome rings, we would put bondamy in to the cylinders to seat the rings. Those day are over thank God. Guess you can do like the Brits over across the pond, and drive it till it breaks, and then you know what was wrong with it. Or you could do like we did on dragsters back in the 60's and wrap rags around the breathers to catch the oil. That trick was also good to play mind games with the car in the other lane. That and adding a quart of oil as you staged the dragster. But none of this is going to help you one bit. Pull it out and give us a break please.
I get 170-180 psi on 9/1 engines all day long.....................................the rings will seal to show that in five minutes, the last bit takes a bit longer say hour. Drag race motors go to the strip and max power expecting max compression after the 20 minute cam break-in.......................I certainly did it enough.
There is no night vs. day point at which the cylinder is dead but 10 psi higher it's not, the 120ish mentioned is still pretty much dead for an engine like that.
Could be crap gauge, the cheaper ones can be pretty ratty, I learned early on to get a good one and I'm cheap, cheap. It don't work there.
bad bean
Did another check on compression. This time the cylinders were 125 except the number 6 hole was 110 put a drop off oil it then went to 125. Not sure if overlapping of valves or rings making low or is that OK cylinder pressure. Can or will rings seat after running for some time. I know that someone said that it could be the best they will show after few minutes. Now I have  to figure out about leaks.
bad bean
I did state that it was high compression my bad.my mind is rambling so not getting things always correct.like I stated moments ago.looking for advice not ridicule.I want to thank all again for input.hope I get good compression reading so I give good news before I tear it down.
bad bean
Sorry that I didn't give full description.Some people forget the reason people are on this post is to get answers.I'm just looking for advice. Not wanting to year a fresh motor apart. If I'm over looking something.Got another gauge doing test tomorrow. If leaving out anything you need to know to help please ask.
My bad as well, I get rambunctious over this stuff and have a tendency to say things I shouldn't thus creating problems. I have no desire to actually rip or insult but I sure seem to go there enough. My apologies to all. It just seems that people should think a little more and that certainly includes me. Chalk it up to my lack of patience as I age, not my strong point. Stupid old man we'll say.
".........ru bber glove on pcv, that one's borderline stupid."
I'll take the hit for that one. He had stated that it didn't seem like there was a lot of air coming in /out of the oil filler cap. There seemed to be doubt in his mind that he was able to detect it  I told him to put a rubber glove over the PCV hose as a way of telling (visually) just how fast there the crank case pressure was building - if at all. It wasn't meant to be any kind of a definitive test, just a way of observing that which he was struggling to perceive.
I had tried it once when my Chevy 283 powered Studebaker was showing 150 PSI on the gauge, the valves had both new O-Ring and umbrella seals, the valve stems didn't feel "too loose" and yet it was smoking quite a bit.
And yet asking how much psi without telling any of that...........(chuckling to self) Major omissions like that are why you are here now.......... Just now finding out about the overbore after I mentioned possible not being bored issues twice. Your lack of attention to detail is death playing with a specialty engine like this, the same lack (and resultant damage) would be likely to be expected on the engine itself. No insult intended again, just the facts ma'am.
Rubber glove on pcv, that one's borderline stupid. As in on the OTHER side of that border.
'I didn't say that compression was 12.1...'
Au contrere mon frere. reply #10 says...
' I'm running high compression about 12.1...'
'they told me I would be fine...'
Oh boy, if I had a buck for every time I've heard THAT one......you ALWAYS doublecheck the work. Say piston-to-wall is too tight and you seize piston to gouge aluminum then that ringset is stuck from metal flow and your blowby. Seen that plenty of times with fresh boring, the incompetence is usually worse with the louder the shop crows about how good they are.
Look here, all the flogging in the world not gonna do a thing until you real world either trip over better compression numbers or make them happen by more work. The motor is dead at those low numbers, 100 psi is the point at which cylinder is considered to be not contributing to power even if it is working. A bang up trick ignition (MSD) might fire it but no power because power comes from gas expansion, ergo, COMPRESSION.
In reference to OP issue you must baffle pre-pcv and I'd look at adding more breather as well.
Also do like they teach you in A&P school. After you run the compression check, shoot some motor oil in the spark plug hole on the low cylinders and recheck the compression again. If the reading goes up its the rings. If there is no change its the valves.
bad bean
I didn't say that compression was 12.1 I merely stated that trw piston 12.1,60cc heads 210 runners,motor bored .030, they told me I would be fine for Moly rings.no decking needed..015 piston to deck height, gaskets .041 compressed.compression should be about 10.5-11.1.a fire notch was cut in piston for plug clearances.I don't do machine work so I'm relying on them.only thing I noticed was the cross hatching.cylinder felt smooth.
