Date: 02/04/2018 08:26 am
Date: 02/22/2017 01:58 pm
1976 Ford Pinto Pony
Date: 09/06/2018 05:40 pm
2.3 pinto carb
Date: 08/18/2018 02:07 pm
6.6.75 carrier
Date: 02/14/2018 06:47 am
Date: 11/05/2016 09:03 pm
Date: 07/04/2022 07:55 pm
78 windshield trim
Date: 02/01/2020 08:46 am
Date: 02/28/2018 09:33 am
  • Online today: 506
  • Guests: 368
  • Total: 368
What would be the 4th instrument gauge you would want?
Started by Henrius, September 18, 2014, 12:34:20 PM
78_starsky
thanks dwayne,  understand now.  we can't wait till spring to finish the body on the truck.
cheers
I meant from a creative standpoint.  I think the two of you make an excellent team!
Dwayne
78_starsky
thanks guys,
how do you mean dwayne?
the placement of a vac gauge is me.  (actually anything that includes nuts, bolts or electricity is me) paint and sewing is hers.   ideas are "group think"   lol
cheers
78_starsky
after reading this thread and thinking about it,  you got me thinking....  here is what i came up with.
cheers
Quote from: Wittsend on November 13, 2014, 11:16:23 AM
"Nice find!.."
Were you referring to the tach/boost combination...,  or the fact that the white plastic housing wasn't dust? LOL
The tach/boost is from the donor '88 T/C and the housing modified to fit.
The plastic housing of course, lol..
"Nice find!.."
A BOOST gauge! And..., conveniently it came with the tach.  :) And, miracle of miracles a white gauge housing that didn't turn to dust!
78_starsky
i would go vacuum myself.  adding one in my truck build.  the tach is a nice option too if that is your wish
76hotrodpinto
Quote from: 65ShelbyClone on October 22, 2014, 12:09:30 PM
Is it a narrowband or wideband sensor? As the name suggests, narrowband sensors are only fairly accurate over a narrow AFR range centered around stoich (14.7:1 for gasoline). As a result, they have very limited use for tuning.
I've tried both on different cars, and your right it's not very accurate. But it gives you a good idea of how it's burning thru different rpm ranges and loads with either. It's more about getting the tune just right, and then noting the meter readings and knowing when your falling out of tune. Plus it's pretty cool!
76hotrodpinto
I welded an o2 sensor bung into my header and use a fuel mix gauge. That and the tach are very handy for tuning.
Henrius
Quote from: 65ShelbyClone on September 24, 2014, 12:30:09 PM
Yeah, there are plenty of 2"/2 & 1/16" tachometers out there.
Voltmeters and ammeters I don't really care about if the stock alternator light works. I'm going to install a voltmeter because I already have several and it's better stored/used in the car than on a shelf.
That is the trouble! My alternator light no longer works, and it is not because of a bad bulb!
1973 Pinto Runabout with upgraded 2.0 liter & 4 speed, and factory sunroof. My first car, now restored, and better than it was when it rolled off the assembly line!
A vacuum gauge would be useful for trying to maximize fuel economy.
amxtra
Henrius
Oooh, thanks for this! I can possibly have my dream- a Tach in my dash!
Henrius
Quote from: Pinto5.0 on September 18, 2014, 03:18:43 PM
I like a good amps gauge myself. Easy to spot a current draw or short in the system. Turbo car I'd want boost, automatic trans car that gets heavy use I'd want trans temp & if I was in Arizona or a high temperature state I'd want oil temp.
I agree on amp versus voltmeter! Thinking of switching that.
I will leave the OEM gas gauge where it is.
Don't have turbo or Automatic, so those would not be helpful
What I REALLY want is a tachometer, but cannot find one that is only 2 1/8 that would fit in the space on the dash!
tbucketjack
Gas gauge with the right ohms for your ford sending unit.
Henrius
I am redoing my Pinto gauges in my 1973 dash. I had a bezel from a late model Pinto. I am thinking about having a larger bezel milled for 4 gauges instead of three.
Now I have the engine temp gauge, oil pressure gauge, and voltmeter gauge.
Would a manifold vaccuum gauge be a logical fourth? I am putting a fuel pressure gauge in the engine compartment, and do not really need it in the dash.
