Date: 09/10/2018 10:41 pm
Date: 07/08/2017 08:53 pm
Date: 12/31/2017 11:14 pm
1976 Ford Pinto Pony
Date: 09/06/2018 05:40 pm
Date: 08/30/2021 03:20 pm
Date: 02/04/2018 08:26 am
Two 1978 Pinto Station Wagons
Date: 05/18/2025 03:10 pm
Intake manifolds
Date: 03/06/2021 03:04 pm
72 pinto and 88 turbo coupe
Date: 06/09/2016 04:13 am
  • Online today: 131
  • Guests: 50
  • Total: 50
stock 2.0 pinto radiator enough for turbo 2.3 motor
Started by biggrgivens, September 15, 2014, 04:34:51 PM
CU426 is the larger Pinto radiator for AC cars. CU981 is the Dakota radiator I used on my 80.
You have to make mounts but it's easy.
http://www.fordpinto.com/your-project/here-is-my-'80-hatch-i-call-callisto/msg129574/#msg129574
What year?  If you have a 2.0 I believe only the '74 Pinto had a plate to use the smaller 2.0 radiator in the larger opening.  So if your Pinto is a '71-'73 you will likely have to increase the cradle opening for a larger radiator. See the last picture, the cradle was widened about 3"-4" and the metal overlapped to provide strength. With the 2.3 Turbo (no mechanical fan) in a '71-'73 car the clearance in very small (see middle picture). An FYI, the '71-'73 has a 17"radiator and the 2.3 cars had a 20" radiator (See first picture).
Do a search, as that was just talked about on here. Think it was a V-6 Dodge mini-pick up. 2.0 radiator isn't good enough for a warmed over 2.0.
biggrgivens
I am dropping in a turbo 2.3 svo motor and wanted to know if the 2.0 radiator is enough to keep it cool. If not what aftermarket radiator do you suggest that will fit in the pinto stock location?
