79 pinto driveshaft
Date: 08/18/2018 02:03 pm
Wanted early pinto
Date: 10/03/2019 02:42 pm
Date: 10/10/2019 10:02 pm
Date: 09/15/2019 12:28 pm
2 liter blocks and heads
Date: 03/28/2018 09:58 am
76 drivers fender
Date: 07/20/2018 08:24 pm
1980 Pinto w/ Trunk
Date: 08/10/2022 04:09 pm
Date: 05/18/2020 10:22 pm
78-80 Windshield
Date: 10/29/2021 03:11 pm
  • Online today: 178
  • Guests: 71
  • Total: 71
Replacement spindles, is it worth the extra to buy the IMCA version?
Started by russosborne, September 07, 2014, 05:13:50 AM
Actually I don't much care for Wilwood. All I want is the Granada upgrade that Summit sells for $250 or something. I like being able to go to any auto parts store and getting replacement parts.
thanks,
What you need is the Wilwood 140 - 11017 brake kit.
Bigger brakes & 5 bolt hubs......I happen to have a new kit.....
Wilwood site says for 71 - 78 cars. Turns out it's for 74 - 78 only. Couldn't return it.
Thanks.
The problem is the car may have hit a brick wall. :-\ It hit something or was hit very hard.
The driver's side frame/fenderwell was replaced from just in front of the crossmember forward and most of the radiator support as well. I don't know if they needed to or did replace any of the suspension, so I am just going to replace all of it. Better safe than sorry. It just won't happen anytime soon.
But it sounds like the IMCA parts would be wasted money, so I will just get the cheaper stock replacements.
Only difference with them and Ford spindles, is they are IMCA approved. Never saw a bad Ford spindle unless the car hit a brick wall. They will out last the car many times over. Use what you've got.
I was thinking maybe they are stronger, but after reading the catalogs I am not sure.
Thanks,
