Date: 01/10/2022 03:41 pm
Date: 04/15/2017 05:14 pm
Date: 03/05/2017 03:27 pm
1974 Ford Pinto
Date: 10/16/2017 10:45 am
Mustang II V8 swap parts
Date: 03/26/2017 02:25 pm
Date: 03/27/2017 10:07 pm
1976 pinto for sale
Date: 01/12/2017 02:08 pm
Date: 04/25/2017 12:17 pm
1976 Squire wagon
Date: 09/12/2018 10:30 pm
  • Online today: 1,972
  • Guests: 1019
  • Total: 1019
Ordering axles for the Mustang II/Pinto 8inch rear for converting to 5lug update
Started by russosborne, September 06, 2014, 04:07:21 AM
Moonman! More info please. Are the brake kits still on E-bay? Does it really stop better? Thanks
moonman
I have a kit i bought on e bay that converts the rear drums to 11 inch disc set works great.
streets the game, sneaks the game love to go fast in Little cars.
I swapped my '73, 6-3/4" out for a '78, 8".  When I got the Mustang II 8" I was very glad I opted for the "Drum to Drum" purchase (it was only $10 more).  I found out that though the brake diameter on the friction area is the same, the center hole for the 6-3/4" was too small to fit the 8".  So, maybe things changed at some point but in my case the 6-3/4" rear drums did not fit the 8" rear.  It would seem logical that the other way around it would work - sort of. That being the 8" drum would fit on the 6-3/4" rear, but the center hole would be too large and would rely on the sloppier lug bolts for centering. More than likely that would cause an eccentric action and pulsating brakes.  As it was I welded the 6-3/4" rear to the donor Turbo Coupe when it was hauled off.  So, I had to use one of the 6-3/4" drums with the parking brake anyway.
Regarding the drive shaft some setups work and others don't. In general I believe there is a 1/2" to 1" difference.  I was fortunate. I went from a C-4/6-3/4" rear to a T-5/8" rear and the original shaft fit perfectly.
I can't remember for sure but I believe the driveshaft length is different, but I could be mistaken. Been a long time.
But otherwise it is a total bolt in.
As long as we are still talking the Mustang II 8 inch rears that is. They were made for the II and the Pinto.
Brakes (backing plates/drums/shoes/hardware/size) are the same for 6 3/4" and 8". All the same for Mustang II and Pinto. All will interchange.
dianne
Quote from: russosborne on October 05, 2015, 05:19:39 PM
Chris,
It's the exact same one.
Leaf springs are different, but the housing and axles are the same II or Pinto.
They bolt right in Russ? I have an extra 8" here.
Vehicles:
- 1976 Mustang II mini-stock
- 1978 Mustang King Cobra II
- 1979 Ford Pinto Runabout
- 1986 Chevy K5 Blazer
- 1997 Suzuki Marauder
Chris,
Russ: Is the 8" Ford Mustang II axle the same 8" they would have used on the Pinto? I pulled one from a 1978 glass hatch that had the 2.8L engine, auto transmission, mag wheels - white with red accents. It was like the "sport package" or something. The code on this axle begins with WDY-AL, which is a 3.4 gear ratio.
I just checked the tag on my 6.75" rear end, it's WGB-U which is 3.18 gear ratio.
entropy
1972 Hoonabout
SBF swap
-308 cid
-CNC ported Brodix heads
8" rear 4.11 posi
G-Force 5 Speed
10 point rollcage
Updated Sep 2018 to add an active link.
I used to be really active on a couple of Mustang II sites when I had one several years ago. I thought I should go back to them because I knew there was more info there than I could remember.
I re-found the following, it gives measurements and some good info on how and what to order.
http://www.mustangiitech.net/index.php?option=com_content&view=article&id=80:moser5lugrearaxles&catid=48:drivetrain&Itemid=123
Ok, this link has been dead for a while. :(
I was just exploring and found this
https://www.stangnet.com/mustang-forums/threads/ordering-new-axles.738531/
Post 15 has the measurements. I think someone copied it from the mustangiitech site before it went belly up again.
I hope it helps others.
