Date: 02/28/2024 02:07 pm
77 pinto cruz. wagon
Date: 06/15/2017 09:18 pm
77 Wagon rear hatch
Date: 12/04/2019 05:57 am
Brake rotors
Date: 03/24/2017 09:02 pm
Date: 05/21/2019 11:50 am
72' hatchback parts wanted
Date: 08/25/2019 02:57 am
74 hood
Date: 07/03/2017 03:46 pm
Date: 11/14/2019 04:02 am
Date: 12/31/2017 09:03 pm
  • Online today: 488
  • Guests: 456
  • Total: 456
Besides the FOG and T5, will any other manual trans work with the 2.3?
Started by russosborne, August 22, 2014, 01:38:53 PM
AndrewG
Yep, I currently am wire wheeling the engine compartment and painting it. Might as well, I have no money for big things like transmissions at the moment and this keeps me busy.  ;D
AndrewG
Quote from: russosborne on August 23, 2014, 12:28:18 AM
here is a link to a discussion here that is for the T9 but also touches on what needs to be done for a T5.
http://www.fordpinto.com/general-help/type-9-on-a-2-3-bellhousing/msg151512/#msg151512
Thanks for the details Russ.
I figured there would be major work related to the mod, but good to know there are options.
(New avitar?  Is that where you're at with your Pinto project.  Very ambitious!  Can't wait to see it when it's finished.)
With the T5 the main issue for you would probably be that the shifter is a couple of inches forward of where it is on the FOG and you would have to cut your trans tunnel, and make sure there isn't interference with anything else on your car. There are a couple of other mods, the main one being with the crossmember, but since your's isn't a Pinto that is something else you would have to look into. There have been a few discussions about this here.
I don't really know anything about the T9 conversion. There ought to be some stuff here somewhere about it.
The Ford Ranger trans bolts up, but the shifter is way too far forward for Pintos and probably your car, along with other possible problems.  On the Pinto the shifter would be hitting the dash.
I was hoping maybe a real trans would work, like a Toploader or Muncie, but seeing as I am stuck with the 2.3L like you I don't think we have many other options.
AndrewG
Quote from: russosborne on August 22, 2014, 01:38:53 PM
Without major mods, that is. Mods similar to the T5 would be fine.
Thanks,
Quote from: dennisofaz on August 22, 2014, 05:02:37 PM
Hi Russ,
I think another trans is the T9 from Merkure.  Also it is supposed to put the shifter in the right place
I've been reading this post and wondering if those options would work for my situation.  I have the 2.3 Lima with the 4 speed FOG and I'm having a difficult time finding parts for this 1980 trans. (as you might have read in the other posts.)
Would you recommend that T5 or T9 option in my case? If so, what mods would be needed?
dennisofaz
Hi Russ,
Thanks,
