Parts Parts Parts
Date: 09/08/2018 03:13 pm
1973 Interior parts wanted
Date: 01/02/2017 11:02 pm
pinto wagon parts
Date: 12/19/2019 01:43 pm
Date: 03/17/2019 10:15 pm
Date: 02/16/2019 10:46 am
1976 Pinto runabout
Date: 03/28/2017 08:14 pm
Cruiser Dash Gauges
Date: 12/04/2016 11:50 am
Date: 08/30/2021 03:20 pm
Date: 07/17/2018 09:49 pm
  • Online today: 116
  • Guests: 65
  • Total: 65
1979 Turbo Pinchero project
Started by CanadianBatman, July 25, 2014, 11:47:20 AM
CanadianBatman
Haha hey say what you want. I was raised on Ford for breakfast lunch and dinner, but that damned Vega is the best runner I've had. I've towed everything in that car. And the diff fit like a glove. I've even slept in it multiple times and had it in two major Canada day car shows.
It's a completely stock 1977 Vega Hatchback 4 cyl 4 speed. Black leather interior and bright orange outside. And it's unrestored. Sat in a garage for 15 years. Still has the experimental aluminum/silicone block, cast head and hypereutectic pistons. Early motors where sleeveless!
1979 Pinto Pinchero Custom body Truck!
1977 Vega stock 4cyl 4speed
1987 Chevette Scooter 2dr 4spd
I'm still trying to process the idea of you using a Chevy Vega as your parts hauler! :o
If you need work / help with it, contact Dario in Calgary. Supposed to be good & is a fellow Pinto guy.
https://www.facebook.com/InfamousAuto
CanadianBatman
Sniped a diff from pick n pull this weekend. Out of a '79 mustang giha. It's an 8"!
I planned on adding an aftermarket tach and gauges myself. I did see somewhere where someone put TC gauges in the Pinto cluster though.
CanadianBatman
woohoo! you guys are awesome! speaking of wiring harnesses, what are you guys doing for a dash cluster. obviously the speedo isnt compatible. are you just using the turbo coupe dash, or custom building your own?
It won't be hard with a wiring diagram. Scroll down to "PEtoLA.pdf":
http://www.rothfam.com/svo/reference/
An '86 ECU schematic is on the last page of the pdf. Then you can just grab a connector and find the pins in the ECU plug.
CanadianBatman
Yaaay wiring harness work. I have a long night of wire tracing ahead of me.
CanadianBatman
Far as I know the pipe is original. Still has the correct t3 turbo. Mine didn't even have the lifting eye. I had to sling the chain around the exhaust manifold. That was a tight fit and a sketchy lift.
It's interesting that your '86 has the finned compressor outlet tube. I'm pretty sure that only Merkurs got it.
Was the hoisting loop at the back of the exhaust manifold broken off on your engine too? I ended up using a 12mm head bolt in the hole near that point...and it got bent lifting that iron lump!
CanadianBatman
got a bunch done on the weekend. Stripped the motor out. And split the tranny off. I'm going to put in a new clutch/flywheel. I'm in there, might as well. Just a couple things left in the donor car and it can roll down the road.
Get the mess of fuel pump wiring, fuses, inertia switch, and relays that go from the ECU into the trunk. Emphasis on mess; you'll probably have to pull the rear seat and get under the passenger-side carpet.
Also get the throttle cable and maybe pedal. I haven't reached that part of my swap, but I do know the stock 2.0 cable is too short.
CanadianBatman
Time for the big move! I got a random week off of work. And now my big plan is to have both the motor from the TC and the Pinchero Pulled. I want to do some quick tear down work on the turbo motor, and i need to rebuild the Transmission, but if i can have the motor and all other connected equipment out so that i can be rid of the shell. I already have the wiring harnesses seperated, and it should be a quick pull and run. Is there anything generally skipped over that i should be taking from the turbo coupe?
82expghost
i used the late 80s mustang 8.8 cut the mounts off and welded on the perches and it fit perfectly under my 77, the hard part was getting the old rear end off. i would do it again. the problem with the explorer rear is you dont have the 4 lug, the disks are huge so you have to ballance the brakes, have to cut out the axle tube, hope you get that tube on perfect so you dont keep blowing wheel bearings. i find the mustang 8.8 is also the cheapest per performance ratio. unless you plan on making 500 or so, i think the late 80 mustang is the only way to go
98 taurtus, now in heaven
77 pinto, weekend warrior
92 grand marquis, daily
I think ease of installation goes to the 8" and 9" rears. The lower entry fee on an Explorer 8.8 is offset by all the modification they need.
BUT...I'm finding that none of the sorry chain stores around here stock basic 8/9" repair parts like seals and axle bearings. I can get carrier and pinion bearings and crush sleeves all day long, but not the stuff that actually wears out in less than 40 years.  ::)
don33
8.8 are plentiful, a dime a dozen. theres got to be hundreds of thousands of explorers in the yards... I think I paid $235.00 for mine, complete. it came with a 373 ratio, track lock diff, disc brakes, 5 lugs and large 31 spline axles. If that aint a deal I don't know what is... 8) the 8.8's are pretty easy to work on, I took mine apart and reassembled it, wit no experience whatsoever... but, which ever way you go, you'll have a good setup.
CanadianBatman
Here's a couple pictures of the bed. And yes that is a goat in the first one.
I would love to go with an 8.8 and if I find one in the yards or private sales around here, but my chances are a lot higher that ill snipe a 9 in one of the scrap yards. Plus I've already done a rebuild on a 9 so I have -some- experience with them.
dianne
I'd love to see a picture of what that bed looks like :)
Vehicles:
- 1976 Mustang II mini-stock
- 1978 Mustang King Cobra II
- 1979 Ford Pinto Runabout
- 1986 Chevy K5 Blazer
- 1997 Suzuki Marauder
Quote from: 65ShelbyClone on August 06, 2014, 05:18:26 PM
Nines are tough, but they're really heavy and zoop up a bit more power.
Huh....this forum's software is set up to replace bad-sounding words like $uck with "zoop."
Nines have a lot of pinion offset and the necessary spiral angle on the teeth causes a lot of sliding between the gear teeth, which causes it to soak up a bit more power than other designs. That is what also makes it stronger because it creates large contact areas between teeth and across multiple teeth at the same time. One thing is for sure though, a factory 28 or 31 spline T-lok 9" chunk is 1000x easier to find than any factory T-lok 8" carrier. If you can find a 57" nine rear, roll with it I guess.
don33
I don't know why you would go with a 9", an 8.8 is lighter, just as strong if not stronger, and has less friction during operation.
http://i1368.photobucket.com/albums/ag174/don3310/DSC00891_zps54b0b228.jpg
narrowed ford explorer 8.8
I dragged home an 8" out of a Mustang II, so that was the "easy" way to upgrade in my case. Nines are tough, but they're really heavy and zoop up a bit more power.
The alternator wiring is in the driver's side portion of the T-Bird lighting harness, but I don't think you'll really need it. My TC alternator has the same connections on the back as the one out of my Pinto. They are both externally-regulated "1G" (first generation) Ford alternators.
I'm going to use a 130A "3G" alternator myself and it does need wiring alteration due to being internally regulated.
CanadianBatman
Yeah looks like I'm going to have to go with a 9". I don't like breaking stuff. As fun as it is. Haha easy enough to weld spring mounts and the whole 9 yards I have access, limmited, but access to a welder.
The project is coming along nicely, every little bit helps. Got the wiring harness in the thunderbird stripped, everything labelled. Looks like the engine harness and the body harness are mostly separate. A couple things I have to weed out, like the alternator wiring is in the body harness. Blegh.
Yeah, even 5.5" BS wheels won't fix that spacing. Those are "Pony" wheels that came standard on 91-93 Mustang GTs and were optional on 5.0 LXs.
The '87-88 TurboCoupe rear is a Traction-Lok 8.8" with disc brakes and it is also 61" wide. It is/was a popular swap for Fox3 Mustangs, but makes the wheels stick out. Interestingly, only the axles make it wider. The "easy" way to narrow it was to install the shorter Mustang axles and either flip or modify (I forgot which) the caliper brackets. The '87-88 TC rear also came with either 3.55 gears or 3.73s.
I have read only speculation that the earlier 7.5" drum rear can be narrowed in a similar fashion.
Quote from: CanadianBatman on August 01, 2014, 01:53:12 AM
This interests me! does anyone remember someone using a Turbo coupe rear end in a pinto? i dont mind a little wheel spacing. this would work perfectly as i have an entire donor car, and that rear should take the power i want to generate, without grenading. Ive been looking around to see if i can find anyones swap in the archives and everything, but ive come up empty.
Thanks so much for all of the help and info!
I corrected my previous post. The rear end in your '85 'Bird is 7.5", not 7.25.
Regardless, I wouldn't invest work involved with using the 7.5" (I know it's really tempting because it's right there) if your ultimate goal is 400hp, especially if any hard launches are planned. The 7.5 will live a lot longer under a lightweight Pinto that it would under a 3400lb 'Bird with the same power, but I don't know what the limits are.
Do it once, do it right, and do it with an 8" or larger rear end. Get the 8.8" T-Lok out of an '87-93 5.0 Mustang if you want a project. The gears will be 2.73-3.08, but it should also be the right 57" drum-to-drum width for a Pinto/early Mustang.
Below are a couple old photos from ebay showing a 73 Pinto with a 87TC rear and 16" Mustang rims.  The tires do noticeably stick out a bit.  The 87TC rear is different from your 85TC but the width may be the same (don't know).  There are several threads here on narrowing Explorer 8.8" rears for Pinto use.  Nice Pinchero conversion.
CanadianBatman
Quote from: 65ShelbyClone on July 30, 2014, 12:40:24 PM
As an FYI, the 'Bird has a 61" wide (drum-to-drum) 7.25" Traction-Lock rear end most likely with 3.45 gears. I have heard of people using Turbo Coupe rear ends with Fox3 wheel offsets, but could never find anything on exactly how well it fit under Pinto wheel wells. The 10-hole wheels have 5.00" backspacing, so they would still stick out pretty far on each side....I would think.
Get Dario in Calgary to mod a newer Ranger diff !
Think they 8.8 - only problem I see is the 4:88 gears.
Be in 3rd before you are through the lights  ;D
Quote from: CanadianBatman on July 28, 2014, 11:26:58 AM
Thanks guys! It's looking to be a challenge, this is my first engine swap. My hopes are for around 200 horse on the road for the first time I take it out, And build from there.
200rwhp should be fairly trivial with stock parts, an intercooler, and 2.5-3.0" exhaust. The intercooled 2.3T cars frequently made their rated flywheel horsepower at the wheels. Ford has been pretty good about underrating their performance engines since then. ;D
A large VAM+ECU and E6 manifold would make 200rwhp easier though. I don't think any 1985 ½ cars were titled as 1985s; just 1986.
QuoteAt 200hp do you guys think it's a necessity to build a roll cage to strengthen the frame, or should I be okay for now? By the time I figure I'll be "done" with the car, I want about 400 out of it, but By then I'll have a cage.
Subframe connectors would probably help bridge the gap between a cage and nothing at all.
Quote from: CanadianBatman on July 28, 2014, 11:04:12 PM
Well...it's a 6.75 rear...damn. wgf-an on the axle tag. 308 gear ratio though. Probably won't hold up to 200 horse eh?
I asked this same question recently in General Talk:
http://www.fordpinto.com/general-pinto-talk/powertorque-limits-of-a-stock-6-75in-rear-end/msg151107/#msg151107
As an FYI, the 'Bird has a 61" wide (drum-to-drum) 7.25" (Correction: 7.5") Traction-Lock rear end most likely with 3.45 gears. I have heard of people using Turbo Coupe rear ends with Fox3 wheel offsets, but could never find anything on exactly how well it fit under Pinto wheel wells. The 10-hole wheels have 5.00" backspacing, so they would still stick out pretty far on each side....I would think.
don33
Quote from: CanadianBatman on July 28, 2014, 04:38:42 PM
A few other things that have me thinking are, I will need a pinto pickup/oil pan and engine mounts right? Also will I have to weld in the bases for the mounts? I've been searching, but unable to come up with an answer. A few guys have had to, but that's in early bodied cars whereas mine is a 79 with an 85 donor and I'm going from a v6, auto and I think an 8" to turbo 4, manual, 8".
yep, you will need a 2.3 pinto oil pan/pickup and engine mounts. not sure about the bases. I don't have any experience with the 6.75 rear, but they were made to deal with 80 or 90 HP. If it were me, I'd be looking for an 8", especially if you see some possible spirited driving in your future...
CanadianBatman
CanadianBatman
