Date: 03/07/2017 07:03 pm
Wheels and Parts
Date: 07/06/2018 04:50 pm
Date: 09/15/2019 12:28 pm
Wheels and Parts
Date: 05/22/2018 01:54 pm
Automatic transmission
Date: 02/13/2021 02:52 pm
Date: 07/08/2017 08:25 pm
Date: 01/28/2021 03:49 pm
Date: 10/10/2019 10:02 pm
  • Online today: 148
  • Guests: 94
  • Total: 94
2.3 turbo swap in a 73 pinto over heating problem
Started by little red, July 23, 2014, 06:02:36 PM
I'm running a stock Pinto 20" radiator in my '73 Turbo Pinto. I had to cut the radiator support and move it over. As the pictures hopefully shows I overlapped the shifted portion to strengthen the area. In the top picture if you follow the upper edge of the radiator opening it angles upward slightly just before going off the edge of the image. That is the original position of the piece that was moved.  I have no cooling problems at all.  I use a generic front mounted fan offset on the drivers side.  The blade size just fits in the allotted area.
You didn't stated how you are verifying the overheating.  There are times when gauges can read high when in fact the actual temperature is correct.  What gauge and sender are you using? If the sender is mis-matched for the gauge the readings can be incorrect.  Also most gauges run on a lower voltage (about 10 volts) and a regulator is attached somewhere under the dash. If that is bypassed then the gauges get full voltage and read high.
I hear that, my biggest fear is having to have someone bore a block or do competent headwork now. All the super good oldschool guys here are gone and the work done is absolutely abysmal, often scrapping the part after they brag about how good they are..............last 3 jobs I had done were each ruined. And STILL had to pay or go to court...............what idiots............
flashback to the early 70's (1971 to be exact.
i had a 3 row (nearly 3" thick) brass core made to fit into the stock mounting flanges with new handmade upper & lower tanks for my 71.
cost me $100
point is this: where is the craftsmanship these days?
i know; it takes time but isn't your car worth the time?
guess i'm just a bit too old school
If not running engine driven fan and aftermarket electric could be trouble there too, often they cannot touch the engine driven airflow. Why even the smallest engines now often have TWO killer fan motors now. But you have to have super alternator output to be able to pull them.
CU426 is the part number for a new brass 2 core A/C radiator that you can get from Autozone or Ebay. It's the largest stock radiator out there & should cool it.
little red
To answer both questions at high and low speed  the factory size of 78 2.3 pinto 1"1/4 thick 17" 5/8 wide  15"1/4 high that the core size I've see that some people out there use what looks like the same radiator setup but I could be wrong
whats up peps I own 73 runabout 2.3t swap, spd, pimp ecu, subframe connectors. Ive had this car for 10yrs and have done the work my self the car has been in my family for 30yrs. Alway looking for parts and I have a few my self too, please feel free to message me
tbucketjack
little red
So I've got my swap done I've got the stock radiator in the cars stock spot  from  the 2.0 and the electric fan blowing  threw the radiator with a switch i have  the fan running trying to keep it cool by running it all the time but it still isn't workin. What are your suggestions to fix the problem  I got new water pump and a 180 thermostat   what have people done to keep the 2.3t  from having this problem.
