1978 Squire wagon 6 Cly
Date: 03/08/2021 10:44 am
Looking for a 1980 windshield
Date: 07/30/2020 04:51 pm
Great Cruise wagon
Date: 12/17/2016 03:39 pm
78 pinto wagon
Date: 03/03/2020 01:07 pm
Weber dcoe intake 2.0
Date: 08/01/2018 01:09 pm
WTB Cruising Wagon
Date: 12/07/2016 05:35 pm
Pinto Parts for sale
Date: 06/19/2017 02:01 pm
79 Wagon with many extras
Date: 07/08/2020 04:18 pm
Date: 03/07/2017 07:03 pm
  • Online today: 515
  • Guests: 392
  • Total: 392
Harmonic Balancer
Started by mysonscar, July 22, 2014, 12:45:12 PM
chrisa850
The "solid" crank pulley (without the vibration damper) is listed as 11/76 and later for manual transmission cars. I have the part number as D7ZZ-6312-A. That would probably work just fine... if you can find one.
enzo
When I decided to rebuild mine, I found a book written by Sven Pruett titled "How to build and modify Ford 60 degree V-6 engines" copy write 1994.  In the book it states "Over the years, several different kinds of crank dampers have been used on the Ford V-6.  Most of them were solid cast iron and did very little to dampen anything. For a brief period in the mid-1970s, some 2.8-liter engines were equipped with a true vibration damper.  These units had an elastomeric ring just like those fitted to the small-block Ford engines.  These dampers are fairly rare."
I had two engines to work from and truly don't remember what I put on the rebuilt one.  But, I do have a balancer described above on my shelf.
chrisa850
As it turns out, the car in question is an early 1976 V6 car with power steering and A/C. It's not a 2300 at all.
chrisa850
Here is the exploded view. The part labeled 6A312 will be the crankshaft pulley.
chrisa850
I believe you are looking for the crankshaft pulley. I've attached the page from the 73-79 master parts book.
For a 1976 2.3L engine with air, I believe you are looking for D42E6312-BA, D42E6312-BC, D42E6312-BD, D42E6A312-CA, or D4FZ-6A312-D
I've sent you a private message about a possible source.
dennisofaz
Hi MSC,
If you have a 2.3L engine then you can contact Esslinger Engineering.  They might have a used one.  Also they sell brand new ones but they are smaller in diameter.  The smaller dia. might cause the accessories, Alt. power steering, to not work properly until higher engine RPM's
Dennis
Go to the local dirt track that runs Mini-Stock Pintos.
mysonscar
Would you have ANY idea where to find this part?  I have been on the internet and made almost 30 calls. My son goes to college  in less than 2 weeks and this is his daily driver. PLEASE HELP.
Yes! The pulleys only bolt on to the hub. Thing does not look like a small block Ford.
mysonscar
The mechanic said that the pulleys are separated?  This is a complete learning experience for us. Am I looking for the wrong part?
There is no harmonic balancer per say. Only a hub on the crankshaft about 4" in dia, that the pulleys bolt on to. At least my 2.3L engines are that way.
mysonscar
My son needs a harmonic balancer for a '76 Mercury Bobcat.  We have looked at salvage yards and JC Whitney. Tons of ebay ads with no luck. Any help would be appreciated immensely.
