1973 Pangra
Date: 01/06/2015 02:19 pm
Date: 09/10/2018 10:41 pm
Date: 10/11/2019 11:13 am
Date: 03/16/2017 10:00 pm
Date: 01/06/2017 11:42 pm
74 Pinto Rear Side Lights
Date: 02/18/2017 05:47 pm
2.0 Cyl Head1973
Date: 11/29/2018 12:51 pm
cam pulley
Date: 05/30/2018 04:56 pm
Wanted 1973 Ford right fender
Date: 06/03/2017 08:50 pm
  • Online today: 116
  • Guests: 110
  • Total: 110
A 1972 turbo swap adventure
Started by 65ShelbyClone, July 20, 2014, 12:39:02 PM
don33
NICE.... I really like that oil pan, did you mod a stock one or buy it ?
The car:
'86 Turbo Coupe donor on the way home:
This is the kind of 28 year-old desert dirt and grime I had to contend with. It was still encrusted after three motor bath + pressure washing sessions. I finally said "Enough!" and pulled the driveline.
After many hours of grueling scraping, degreasing, sand blasting, and painting, this is how the engine is shaping up:
I left the longblock alone and just tidied everything up. I wanted to port the head, intake, and exhaust manifold. This engine has 214k on it already, so I figure it's probably going to come out for a rebuild in the next 50k anyway. I also elected to not invest a bunch of work in the head if it's cracked all to heck...and 80-90% of 2.3T heads are.
I probably shouldn't have pulled the turbo and manifold off without replacing all the nuts and bolts. Time will tell if they relax and cause leaks.
I am going to be using a MegaSquirt-II v3.0 standalone EFI controller, which needs to have an intake air temp (IAT) sensor. My '86 engine had an IAT in the air meter, which I am not using. This meant poking a hole in the lower intake and mounting a sensor like an '87+ engine. Left hole is for the knock sensor, right one that's fuzzy is for the IAT.
'85.5-86 "square" EFI intakes like mine have the tall upper part. In '87 they were shortened to fit the TurboCoupe. At this point I am not willing to blow a big ugly hole in my stock hood or cut up the intake, so I have to make a low-profile upper intake plenum that faces forward. This is the start:
I have made some progress since taking these photos, but nothing very noteworthy. I'l probably relocate the alternator to where the 2.3t's A/C compressor was in front of the turbo so I have lots of room to deal with throttle body positioning. That is also where the 2.0's alternator is, so maybe a little wiring to do too.
