Bumper Guards
Date: 03/28/2017 09:27 pm
Alloy Harmonic Balancer
Date: 07/10/2020 12:17 pm
Date: 05/24/2020 08:19 am
77 Wagon rear hatch
Date: 12/04/2019 05:57 am
Date: 05/19/2018 04:56 pm
Pinto Wagon
Date: 05/25/2018 01:50 pm
PINTO TRUNK LATCH & CATCH
Date: 03/23/2018 09:39 pm
Date: 04/20/2017 10:10 am
Pinto Wheel Well Trim
Date: 03/29/2017 11:35 am
  • Online today: 1,166
  • Guests: 364
  • Total: 364
Station wagon specific parts?
Started by russosborne, July 02, 2014, 08:18:38 PM
lugnut
I am pretty sure that the doors are different on wagons- at least in the area of the window frames.
If you gotta, you can cut the top off and weld on other, I did on my '80 when I couldn't find shocks for it. I've even rewelded bottoms but much riskier since sealed shock body there, you need a welder with patience to do it correctly.
Quote from: OhSix9 on July 15, 2014, 07:52:25 PM
A good alternative for wagon rear shocks are Late 70's Pontiac Firechicken. Also available as a coil over and adjustable. Length is right.
Firebird shocks have a tie bar upper mount & stud lower. They won't work. Try a set of these on sedan shocks.
http://www.summitracing.com/parts/mrg-1290/overview/
Any more specific years/model of Firebird (and I assume Camaro too)?
OhSix9
Virgil to Sid
The rear shocks for sure are different length. I do not know if the shock rate is altered also.  Being cheap like I am I have altered a "regular" shock and it works well on my wagon (regardless, do at your own risk).
  I simply use spaces at the top and bottom to compensate for 1-1/2" (max you can get) of the 2" extra length that the wagon shock has.  This keeps the shock "centered" and frankly I have never had a situation where I have noticed them bottoming out.  The wagon rear shocks are harder to find (though available) and typically cost more. The picture shows the spacer on the bottom, but I have one on the top too. In fact, if you have a bunch of shock washers stacking them will accomplish the same thing.
sedandelivery
I know on my '80 hatchback the rear bumper mounting is different than my Sedandelivery, but the bunpers themselves are interchangable.
russ ,easy fenders forward are the same doors back are different seats ,door panels and dash area are the same. glass windsheild same what parts do you need?
Shocks, that is important.
Thanks!
Longer travel in rear end of wagon to be able to load vehicle with more weight. Rear shocks are different too. Fronts same as other.
dianne
Quote from: russosborne on July 03, 2014, 03:42:42 PM
Shiny stuff? What's that? :P
right now I am not even sure what this thing is supposed to have. Between being a wagon and a 74, I am just about totally lost.  :-[
Thanks,
LOL look at the pictures of the wagons here :)
Vehicles:
- 1976 Mustang II mini-stock
- 1978 Mustang King Cobra II
- 1979 Ford Pinto Runabout
- 1986 Chevy K5 Blazer
- 1997 Suzuki Marauder
Thanks,
dianne
Chrome all over the place :) The roof is different of course :)
Let me know if you need the chrome moulding, have some extras from Dave!
Vehicles:
bbobcat75
rear springs - longer and handle more weight - not much more!
1975 mercury bobcat 2.8 auto
Thanks. I hadn't realized that the rear suspension would be different.
all the other stuff so far makes sense.
Rear suspension is somewhat different..............exhaust further back............rear electrical harness for sure.
bbobcat75
rear interior panels, doors - door trim and body trim from doors back - sure there is more!
Can anyone point out a post here or tell me what are wagon only parts, and more importantly where to get them?
Obvious ones are the gas tank(from what I read here), headliner, and tail lights.
If it matters I have a 74.
Thanks,
