1980 Pinto Pony for sale
Date: 08/21/2021 03:54 pm
78 fender and hood
Date: 03/23/2021 01:07 pm
Date: 09/15/2019 12:28 pm
Date: 02/10/2017 09:30 am
1976 pinto for sale
Date: 01/12/2017 02:08 pm
SEARCHING HOPELESSLY
Date: 02/02/2017 07:21 am
1980 PINTO for sale
Date: 06/19/2017 02:51 pm
1980 cruising wagon ralley
Date: 07/12/2019 01:41 pm
  • Online today: 344
  • Guests: 245
  • Total: 245
Using stock fan on a Turbo SVO 2.3 motor
Started by biggrgivens, July 01, 2014, 11:47:44 PM
Yah, long or short, that pulley must line up, then you mod fan spacing itself and separately.
I'm thinking there is no shortest water pump.  Remember the water pump pulley has to align with crank pulley. If your car is '74 and up you should have sufficient space already. If you put the 2.3 in a '71-'73 there is minimal space. I think there is about 3/16" between the bolt and the center rod in the picture.  I run an electric fan without issues. I use the whole Turbo Coupe relay box. The fan is basically generic with a mount made from angle iron. My only issue is fingers and fans. thankfully the fans don't run with the engine off.  Here are a few pictures.
biggrgivens
Going to start putting the 2.3 turbo engine together with pinto essentials. Question....I would like to use the shortest water pump there is, so that I can continue to use the stock fan. What pump can I use on a turbo 2.3 motor that will allow me to continue to use the stock fan setup?
