ford pinto door panels
Date: 03/20/2022 07:51 pm
pro stock front end
Date: 06/28/2019 07:43 pm
Need Brakes for 1971 Pinto
Date: 04/27/2018 11:48 pm
Date: 10/10/2019 10:02 pm
Date: 03/16/2017 10:00 pm
Date: 02/16/2019 10:46 am
Date: 08/01/2018 01:27 pm
'79 Ford Pinto, Green,
Date: 10/29/2019 11:50 am
Date: 10/25/2019 03:30 pm
  • Online today: 2,909
  • Guests: 2797
  • Total: 2797
This is project #5 for anyone keeping track
Started by Pinto5.0, June 25, 2014, 08:43:25 AM
Quote from: pinto_one on May 30, 2015, 11:09:08 AM
Hey Reeves, you say B2 headers , is that bronco II headers , if so I have two new sets , only for the 2.8 ,  one is ceramic coated , later Blaine
BOSS 302 - vintage.
QuoteFirst I want to see how well these fit since I plan to move the engine back & down as far as the Milodon oil pan permits
Will still work. Nice thing about the design.
Quote from: Reeves1 on May 30, 2015, 05:40:18 AM
Still cheaper than Canada.
One guy I have lined up for my B2 headers says he can do them for 1500. Before ceramic coating.
Another says customs start at 2500.
I have thought about the ones you have. With pictures, a good builder should be able to make a set, providing he can work with the car as well.
Once I reach the assembly phase on this car I may build my own set. First I want to see how well these fit since I plan to move the engine back & down as far as the Milodon oil pan permits. It wont be huge changes but I think I can go down an inch & possibly two inches to the rear. I'm not crazy about the coating job on these & if I have to re-do them I may as well build a fresh set.
Quote from: dianne on May 17, 2015, 06:54:31 AM
Did you ever get those made?
I can't find a local source to build them. I've called every shop that claims to do racing fab work & nobody will touch them unless I'm willing to spend $800 or more. I could make a set myself using a generic tubing kit from Summit for less than half that. People are on drugs nowadays.
dianne
Vehicles:
- 1976 Mustang II mini-stock
- 1978 Mustang King Cobra II
- 1979 Ford Pinto Runabout
- 1986 Chevy K5 Blazer
- 1997 Suzuki Marauder
Pintocrazed
IF THE PRICE IS RIGHT IT MIGHT BE WORTH IT.IM SURE THERES MANY THAT WOULD LIKE A SET.I KNOW I SURE WOULD LIKE A SET
76hotrodpinto
Quote from: Pinto5.0 on April 07, 2015, 07:29:26 AM
That said, if anyone knows a shop that makes headers within a couple hundred miles of Youngstown Ohio give me a shout out.
I know of a guy in portland oregon. I even have access to an oven big enough to ceramic coat them. Too bad your so far from the pacific.
bbobcat75
1975 mercury bobcat 2.8 auto
Quote from: Reeves1 on April 07, 2015, 05:52:09 AM
Copy Headers please  ;D
I'm still searching for a builder around me. I've checked 2 places & neither will do headers unless it's for their own car.
After 4+ years I finally have my tarantula headers for my V8 install. Now I just need the time to put this car together.
After 5+ years digging up Center Line Champ 500 wheels I finally have a complete set for this car. A pair of 15x4 fronts & 15x8-1/2 rears in Ford bolt pattern. This is one of the few deviations I plan to make from the car I saw every day as a child. The car I'm modeling this one after had slots but my 71 is already going to have aftermarket 14" slots & I love these wheels more.
dianne
Looks like a decent project and congratulations!
Vehicles:
Quote from: Reeves1 on June 25, 2014, 10:34:38 AMDrum brakes on the front ?
Reason I ask, the brake line bracket sticks out a ways like on my blue parts car, which has drum brakes.
It has disc's on it & the pedal pad has the disc logo. That doesn't mean they weren't swapped on at some point though.
 :o
;D
I just drug home another Pinto. This one is a 72 & it makes the 5th project car I'm trying to assemble at the same time. Only this car & the 71 half hatch are mine though. The 73 is going to be my stepson's 1st car, the wagon will be my daughters & the 80 hatch is my sons.
It was only an hour away from my house & the previous owner had passed away recently leaving several project Fords in the garage. Apparently his plan was to make a full time race car out of it.
I can't determine if it ever had a V8 in it prior or if it was on it's way. I do know the frame was never tied & the body & floors are spotless for an Ohio car.
The dash pad is an 8 out of 10 & the sport wheel already found it's way onto my stepson's 73. The auto shifter & pedal will go in it next since I'm installing a T5 behind my 302.
The previous owner cleaned & painted most of the underside saving me a ton of work.
The steering rack was moved & I don't think it will clear my Milodon oil pan so I'm planning to install a late model rack.
It's amazing what a good cleaning can do to make a project look better.
I hung a good door & some clean fenders I had on it & brushed some Rust-oleum on the bare steel.
I decided to use those doors on the 73 so I put the doors Fred sent me 4 years ago on it. These are the doors that I'll run on it anyhow.
I have almost everything I need to assemble this car but it will be on the back burner until I find the time. The 73 is a priority & my wagon engine still needs swapped sooner than later.
