Automatic transmission
Date: 02/13/2021 02:52 pm
Date: 05/18/2020 10:22 pm
1973 Interior parts wanted
Date: 01/02/2017 11:02 pm
turbo 4 cyl and aod trans
Date: 12/14/2019 04:55 pm
1970-1973 Gas Tank/Blue Dash
Date: 02/07/2019 11:57 pm
2.3 front sump oil pan
Date: 02/19/2017 03:24 pm
1980 hood needed
Date: 04/23/2020 10:41 pm
1976 Squire wagon
Date: 09/12/2018 10:30 pm
Date: 12/09/2018 11:35 pm
  • Online today: 236
  • Guests: 223
  • Total: 223
Strut rod bushings for 72
Started by Reeves1, June 17, 2014, 10:17:20 AM
L.D
The kit I purchased from pst had the first cup washer facing the rubber the last cup washer facing away.
Standard stock replacement part by the 'K' prefix, just expensive because Moog, who makes great parts. The one year warranty parts from China that only last 6 months have totally forced them to raise prices on the much better parts to be able to afford say lifetime warranty. That is hard on suspension part companies because of all the people who severely abuse their stuff to demand new part after new part. I saw people tear up suspension parts in 3-4 weeks commonly and back asking for more, maybe 4 times a year doing that. Even best of the best parts. Some drivers are utter butchers especially if 4WD.
Those ones described as "High Performance" Yet I'm not fussy on the design.
I've found OEM ones......now I have to decide on which ones to use.
http://www.summitracing.com/parts/mog-k8196?seid=srese1&gclid=CMqIh72ogb8CFdFafgodv3AAHA
Expand the pic to see the stamped print on the steels, one goes one way, the other flips. Front side steel is cupped to the rubber, back is cupped away from it. You cup the front since the biggest impacts come from that side. It holds the rubber together better to avoid splitting it. The back being flipped allows for the full working distance of the rubber before metal to metal hits since the biggest force there will be springback from impacting the front rubber and the resultant rebound.
I've seen them both ways, but I always put the cup side toward the bushing when replacing them. Worked for me.
Just reading the instructions...
K8196
Says the steel plate/cup on the back - the cupped part faces away from the rubber bushing.
On all my others / originals , they face towards the rubber.
Anyone know why the new ones (Car Quest) have them backwards to factory ?
Raised numbers on all four rubber parts 8415.
Maybe the wrong ones ?
