1970-1973 Gas Tank/Blue Dash
Date: 02/07/2019 11:57 pm
Date: 08/26/2018 06:35 pm
79 pinto driveshaft
Date: 08/18/2018 02:03 pm
1971 Pinto
Date: 03/04/2017 11:28 pm
Need 72 pinto parts!
Date: 06/14/2019 01:40 pm
2.3 bellhousing stick
Date: 07/24/2019 06:50 pm
Wanted hood hinges
Date: 02/17/2020 05:30 pm
Date: 04/20/2017 10:10 am
71,72 Pinto Door Panels
Date: 06/17/2018 08:27 pm
  • Online today: 116
  • Guests: 106
  • Total: 106
What are ya'll doing for intercoolers?
Started by 65ShelbyClone, May 30, 2014, 06:11:26 PM
L.D
what year and size of npr intercoolers are you guys running?
you have to cut the rad support some to put in a npr for where the tubes run through but you can keep the top of the support and the hood latch and all that stuff. and a npr bolts in the same spot as the radiator.
don33
I cut the rad support, But, I'm pretty sure you can use the Large NPR IC. without cutting, it is a pretty good IC, works Well... I like the NPR because its well designed for a minimal IC tubing setup.
I searched. Believe me, I search before starting a new thread. ;D
I'm still gathering info for my 2.3T swap. The engine I have is out an '86 'Bird, so it's not intercooled and I will likely run it that way for a while. However, I want to unlock the full 205hp potential of the setup and that means using an IC. I have an '87-88 'Bird IC that might be useful with custom tanks.
Catch #1: I want to avoid cutting up the radiator support, so that means routing tubes through the big oval hole on the passenger side, which means an intercooler with in/out on the same side.
Catch #2: I want to fit an A/C condenser somewhere between the grille and radiator too. I was thinking about an intercooler on one side and a condenser on the other rather than placing one in front of the other as is usually done. I haven't yet looked to see what sizes and shapes of condensers are available and/or suitable.
Anyone with experience or ideas doing something similar? Suggestions, critique, etc are welcome.
