1971-1975 Pinto
Date: 01/09/2017 04:14 pm
Windshield
Date: 01/15/2022 09:31 pm
Wanted - 71-73 Pinto grill
Date: 12/15/2016 03:32 pm
Pinto drive train
Date: 06/29/2018 08:32 am
Date: 02/08/2018 02:26 pm
78 windshield trim
Date: 02/01/2020 08:46 am
Brake rotors
Date: 03/24/2017 09:02 pm
A.c. alternator hrackets
Date: 09/03/2017 12:11 pm
Tire needed p185/80r13
Date: 12/31/2017 09:08 pm
  • Online today: 344
  • Guests: 92
  • Total: 92
power steering lines leaking
Started by nightrider_76039, May 20, 2014, 03:40:35 AM
No such thing as 'porcelain' washers unless something exotic, cars don't use them. Teflon seal what you are most likely looking for there. White plastic looking thing. Or line seals at the fitting with metal to metal seal. Nothing you can put in there to make it seal better, the metal flare must be in useable condition. The threads themselves do NOT seal (not even intended to!) and putting anything on them only screws things up worse.
nightrider_76039
tell you great mechanics out there I need your help please in high school I had a 71trunk style but it ended up getting totaled out by a guy hitting the right rear quarter panel then I switch to a 72 hatchback then sold it all together. to bring back the high school memories I came across this 78 ford hatchback to bring back some old high school memories.my problem is the bird brain I got the car off of instead of taking the lines loose at the old power steering pum an replacing with new pum he took the lines loose from the steering mech an the leak I'm scared to over tighten an I don't wan to put anything on the threads to obstruct the flow of the power steering flood is there suppose to be a porcelain washer between the fitting and the steering Mac when reinstalling the power steering lines? for the life of me I cannot remember its been so long ago and if so can you please tell me where to find them because I have talked to many auto motive part stores and no one can tell me if there's supposed to be a porcelain washer or where to get one or both if there is suppose to be the porcelain washers Thanks Brain Dead Night
