Date: 04/15/2017 05:14 pm
Front Body parts needed
Date: 02/09/2018 06:09 pm
Radiator
Date: 05/27/2018 06:07 am
Date: 11/04/2018 02:34 am
2.8 radiator
Date: 10/25/2019 04:10 pm
Date: 04/13/2017 04:56 am
Date: 05/15/2022 11:36 am
2.3 pinto carb
Date: 08/18/2018 02:07 pm
Clutch Fork
Date: 03/31/2018 09:12 pm
  • Online today: 197
  • Guests: 196
  • Total: 196
Replacement distributor will not run right
Started by kerryann, May 06, 2014, 05:28:04 PM
 You can't run it to check it or you won't be able to see if the spark lines up or not, nothing wrong with a Duraspark distributor it's no different than any other one.
kerryann
even checking for phase right now would be near impossible.  when i do get it to run it doesnt like it and surges bad and starts to stall, can't keep a steady rpm at all, i fumbled around with the gun while my gf worked the throttle but couldnt make any sense of where i was at.
starting to think i should look into aftermarket ignition systems.  not sure what is available for these distributors
Yes it would be 0*, and yes you can advance it more and you'll have more initial right off, but if you knew how many degrees is built into the distributor you could set your initial right off.
kerryann
just read that rephasing page.  sounds like something that could be wrong.  however i did check the reluctor position on the shaft with the position with the old distributor and they are identical.  i havent yet pulled this distributor apart.  was hoping to not have to but im considering swapping all the old guts into the new one.
just to be sure here, when you line up the rotor nose with plug terminal #1, this is a 0 degree initial timing setting correct?  you have to turn the distributor body ccw to put advance into it for your 6 or 8 or however many degrees initial timing you want.  this is how i timed the old distributor but im just starting to second guess everything here.
Ok, got to thinking about this at the gym and the word "reman" came to mind and I don't know why I didn't think about this before, might be a good thing to check and see if the distributor is out of phase, this article explains it pretty well....
http://www.junkyardgenius.com/ignition/phasing/phasing01.html
kerryann
wires are going the right way.  anything is worth a try. whats frustrating me is that this motor ran great 3 days ago with the stock untouched distributor.  i didnt change anything since then besides the distributor itself.  the timing procedure seems to be just as straight forward as any.  im a pro at getting it in and out now ive done it so many times.  it just won't run right.  something is off somewhere, i think its either the distributor itself or if there is anything else in the ignition box or system that can fail.
Is the firing order at the cap going the correct clockwise 1-3-4-2 direction?
Are you at TDC 180 degrees out? Try swapping all wires with the ones across from each other & see if it fires.
I know those are simplistic questions but even after 35 years I make the dumbest mistakes
kerryann
didnt change anything.  we replaced valve cover gasket which it badly needed.  i did not touch anything to do with cam timing.  i marked every plug wire on the cap so not to get confused, they are in the correct 1 3 4 2 order.  theres no way ive missed the mark this many times.  there has to be something wrong, is there any chance the almuminum motorcraft "brain box" hanging on the fender is messed up now?  spent an entire day today trying to get this to run,  best i can get is a really labored surging part throttle that backfires through the carb.  not sure if i can come up with a stock duraspark distributor.  does anyone make an HEI style distributor for these cars with vacuum advance that rules out the brain box being bad?  are there any tests i can do to any of this equipment?  i'll check ground.  is the distributor grounded to the motor?  if so could dirt and grease be causing a bad ground where it seats?
jonz2pinto
if you had another stock distrbutor to swap out you could rule out new one.when i got stumped i would recheck eveything for the third or fourth time.double check to see if ground screw in dist is tight.did you change anything else that could affect the way the engine runs? Pcv valve hooked up?
Pinto-is short for pint-o-fun.
kerryann
i still have my old distributor.  the reluctor gear sits in the exact same orientation as the new one.  firing order is correct.  cam timing could be off but the car ran perfect before.  i only tried to dig into the distributor to see if i could change the advance slot.  big mistake i guess.  i can get the car to run so i know the thing works but its just way off, surges and dies backfires etc.  when i turn the distributor counterclockwise just about to the end of adjustment i notice i get no spark through the plug checker while cranking.  im stumped so far.
jonz2pinto
if plug wires correct,cam timing correct,and rotor pointing at number one on cap.able to rotate  dist fowards and back.compare pickup in dist to see if teeth line up like old distributor. I know there are different colored plugs on different duraspark modules.may be possible either teeth and pickup in distributor may be off.also wrong dist for your duaspark ignition been awhile since i worked on ignition on a ford or my pinto. Also i have loosened timing belt and turned dist/fuel pump cog to line up distributor.
kerryann
Starting a new thread because my problem here is just with timing.
I replaced my distributor with a parts store reman.  its a 1980 2.3 with low miles.  ran fine with original distributor but wasnt happy with timing curve.  i broke that distributor trying to get the timing plate off (all screws were seized in the aluminum from electrolysis) to change advance slot.
The new distributor is on the 16L slot with bushing and two light springs.  After getting the #1 cyl to TDC of compression stroke i drop in distributor and make sure rotor is pointing right at plug #1.  it will not fire, tries to but wont.  we have spark on plug checker.  if i jump a tooth ahead clockwise and line them up it will run but surge and die repeatedly.  Any ideas as to whats wrong?  This car ran fine 3 days ago with the original distributor.
