1975 Ford Pinto
Date: 01/13/2020 11:02 am
Wheel cap
Date: 04/25/2022 11:21 pm
Oddsnends
Date: 12/20/2016 10:52 am
Date: 06/18/2018 03:47 pm
Pinto Wheel Well Trim
Date: 03/29/2017 11:35 am
Date: 12/31/2017 11:14 pm
72' hatchback parts wanted
Date: 08/25/2019 02:57 am
Clutch Fork
Date: 03/31/2018 09:12 pm
  • Total Topics: 16,268
  • Online today: 354
  • Guests: 174
  • Total: 174
sunroof
Started by jonz2pinto, April 29, 2014, 05:51:42 PM
Runabout75
The roof and cranking mechanism work well. Just cleaned the drains out and that helped with the leakage but I really need to replace the rubber stripping for a better seal.
Runabout75
jonz2pinto
 What kind of maintenance have you done to it?thanks.
Pinto-is short for pint-o-fun.
Runabout75
My 73 hatch has a factory crank back sunroof. Works fine but tends to leak. Cleaned the drains but still have the occasional leak.
Runabout75
jonz2pinto
 What is the right type of lube for the ford crank back sunroof used in pintos.I am trying to get one ready for another member.
So far I have only seen them on hatchbacks.  No wagons or sedans to date.  I had a 75 hatchback a few years back with a working crank back sunroof.  Unfortunately the car was too rusty to repair but I also kept the roof as I could not bring myself to scrap it.
jonz2pinto
i haven't tried it out for a while. I may use some wd40 to get it ready to try. Were they availlable in wagons?i don't think on for sedan will work.
entropy
They're pretty rare.  Rarer still is one that works....   ;-)
1972 Hoonabout
SBF swap
-308 cid
-CNC ported Brodix heads
8" rear 4.11 posi
G-Force 5 Speed
10 point rollcage
jonz2pinto
how rare is the crank back sunroof? I have only seen two.it took both to make one good one.cut top of junked pinto so to have to make it easier to put in one late.no longer have sedan to put it on.
