WANTED Hood Prop Rod
Date: 01/17/2017 02:47 pm
Date: 05/24/2020 08:19 am
Date: 02/18/2017 04:44 pm
74 & Up Parts
Date: 01/20/2021 03:22 pm
Date: 05/22/2018 02:27 pm
1979 hatch needed
Date: 05/13/2018 08:52 pm
Wagon rear quarters
Date: 06/17/2020 03:32 pm
Date: 09/15/2019 08:30 pm
Date: 02/21/2022 11:11 pm
  • Online today: 292
  • Guests: 304
  • Total: 304
oil pressure and other fun stuff
Started by krazi, April 28, 2014, 09:53:48 PM
'I'm having trouble keeping oil pressure after the engine warms up.'
That suggests the light works, to show the difference between cold and warm. Those idiot sensors generally stick on or off, they usually don't change range function. The stock switch; light comes on around 5-7 psi.
Here's the deal. Oil Pumps don't wear by themselves like they exist in another dimension, any wear they have will pretty much always be duplicated in the inner engine. Occasionally not true but usually is. V-6 could have plastic or rubber oil seals, sometime they get old enough to heatcrack in pieces to clog the pickup, if caught quick enough one might possibly save an engine here or there. Keep driving it though like most do and give it up.
So how would you know , right now what is the oil pressure any way ? The OEM gauges are generally speaking crap and go from there.  Just how old is the pressure sending unit? Wiring okay ?  Try to put a test gauge on the oil pressure sender and  get a true reading. Or pull the engine and remove the bearings to check for worn out bearings. That's about it.
I doubt it. Pump pickup tube clogged or motor has dead bearings.
I sold plenty of oil pumps to people who just insisted that the pump will fix it. Nope, commonly 90% later came back and lied saying it worked and later you found they quickly dumped the car or the others were honest and revealed the new pump did nothing.
Oil pumps are one of the most reliable parts on most cars, commonly the problem is usually something else or if truly the pump you can just about guess 100% there will be other damage. Pumps don't wear unless the engine has worn with them. Of course that leaves out the occasional oddball fail like pump bypass valve stuck or simple breakage, rarely it DOES happen.
High volume and high pressure are two different things.
What carb, 2100 or 2150? You cannot mix some parts on them. If 5200 you for sure can't mix certain tops.
krazi
my bobcat wagon has a 2.8. it's one of the 2100 or so that was built in 78 and sold as a 77. I'm having trouble keeping oil pressure after the engine warms up. another problem, I took a carburetor from a 78 bobcat wagon that has a slightly different airhorn on it and put it on the engine. starts and idles better, but runs like crud when I try to drive it. the 78 carb looks to have an extra choke butterfly on it. the one I had in the car came from a 79 and leaked everywhere after about 7 years. it almost seems to be cross-firing. maybe cap and rotor are shot.
someone told me I could put a hi-volume oil pump in it and solve the oil pressure problem.
yeah, I'm Krazi!
