Date: 08/03/2018 09:19 am
76 Pinto Wagon
Date: 07/08/2020 05:44 pm
Mustang II V8 swap parts
Date: 03/26/2017 02:25 pm
Need 72 pinto parts!
Date: 06/14/2019 01:40 pm
1970-1973 Gas Tank/Blue Dash
Date: 02/07/2019 11:57 pm
1977 Pinto Hatchback Parts
Date: 08/29/2020 05:31 pm
Mallory Unilight dist 2.0
Date: 10/25/2019 03:44 pm
Date: 01/10/2022 03:41 pm
1978 fuel sendng unit
Date: 05/27/2020 09:54 am
  • Online today: 489
  • Guests: 224
  • Total: 224
air cleaner idea
Started by poomwah, April 23, 2014, 09:23:21 PM
poomwah
I may wind up chopping up the base of my stocker and doing something with it.
maybe a complete open round filter, maybe dual snorkel on the stock one, but I doubt I'll find another snorkel to match the original one
That triangle one will work BUT ONLY on the two barrel (2CG) model which I had to get straight from Edelbrock. Then you have to change it from a round hole to the shape of the Pinto carb. Was rather easy to do.
poomwah
I have one of these to run on my 80 until I put the turbo in it. It's sized for the 350 Holley I was gonna run but I'll make an adapter to fit the Weber instead.
http://www.ebay.com/itm/SPECTRE-COLD-AIR-INTAKE-KIT-PLENUM-4-INLET-WITH-FILTER-CHEVY-FORD-/221423324238?pt=Motors_Car_Truck_Parts_Accessories&hash=item338ddbcc4e&vxp=mtr
jeremysdad
I've only run open elements for 2 years and have had no water issues. It stays surprisingly dry under the hood, in my experience.
Currently running a K&N, cause the cheap ebay one I started with sucked a hole through the element, and it was the clip style and twisted and just looked funny. It also hit the hood (barely).
It is kinda small, probably be ok for just a driver though, definitely not performance orientated..
That's a really small hose (2 1/2") for a carb. The one Red Line sells has a bigger hose but it also cost more too. Spectre sells one with a single inlet and one with a duel inlet. Both about $100.
Yelby
Where can this one be purchased?
Quote from: 74 PintoWagon on April 24, 2014, 07:47:39 AM
I kinda like this one for a cold air system..
Quote from: poomwah on April 24, 2014, 12:21:37 AM
I may just have to get one of those.  I'd rather have an oval one, but when I find oval ones, they either have the wrong base or they are super expensive.
I like that one because it's 2 1/2" tall rather than 1 7/8" & it's cheap. I've run them on my buggies for years.
poomwah
poomwah
I'm planning to run an open one on my wagon & I think it should be fine in anything but a torrential downpour but it remains to be seen. I bought a $23 one in case it's not gonna work I wont be out a fortune.
poomwah
thanks for the heads up on the rain issue. That one totally slipped by me.
  Are the open element paper filters ok in the rain? or is ANY open element going to be a problem?
With some trimming it should. Just don't get caught in the rain with it.
poomwah
