ENGINE COMPLETE 1971 PINTO
Date: 12/28/2017 03:55 pm
Date: 02/11/2020 12:09 am
72 PINTO WAGON
Date: 09/23/2018 06:16 pm
Date: 09/10/2018 10:41 pm
Looking for a 1980 windshield
Date: 07/30/2020 04:51 pm
Racing seats
Date: 10/24/2019 09:41 pm
Wagon hatch letters
Date: 12/31/2023 04:24 pm
77 Caliper Bolt
Date: 08/21/2018 04:02 pm
Date: 06/05/2018 09:13 pm
  • Online today: 178
  • Guests: 111
  • Total: 111
Fresh start...
Started by jeremysdad, April 20, 2014, 10:03:43 PM
I would go for something like these as a good start. You would still need to buy the velocity stacks, throttle linkage, and air filters but these are rebuilt and will bolt on to your manifold. I would not buy anything outside of the USA unless it was the only way I could get it. These come up on E-Bay fairly often, as do the extra parts you need.
http://www.ebay.com/itm/151289518163?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649
jeremysdad
Quote from: jeremysdad on April 24, 2014, 06:59:44 PM
Ebay sounds like the better deal, then. :)
I saved 3 cents, and got free shipping! :) But, who ran off with the linkage? lol
Can't beat that deal. The linkage will end up semi-custom regardless of how you do it.
jeremysdad
It's 150 miles from me but I drive past there on my run. I doubt he's going to drop any. He wanted $400 for everything with me picking it up.
jeremysdad
Quote from: Pinto5.0 on April 24, 2014, 05:00:08 PM
Yeah, he had everything before you bought the intake. I go past Marengo most days & thought about buying the whole setup but I need fuel mileage out of my 2.0 & too many people have warned me that dual carbs barely get 10 mpg on a good day.
If you live near there, think you can get a better deal in person? :)
If the price is right, I'll make it worth your while. :)
Quote from: jeremysdad on April 24, 2014, 04:10:29 PM
That's the same seller I got the intake from. :/ lol
I prefer IDF's. I have new 40's & the downdraft intake for a 2.3. I just picked up a 2.0 round port Ranger head to run with the combo. I like the idea of dual carbs & filters sticking up 8 inches above the fenders plus I can tune the crap outta a pair of IDF's.
jeremysdad
Regarding the linkage issue, should I throw this in the bucket (with some all thread and a few doubled nuts)?
Link: http://www.ebay.com/itm/Weber-Redline-Dual-2x-40-42-45-DCOE-Universal-Interconnecting-Linkage-Kit-/281064523882?pt=Motors_Car_Truck_Parts_Accessories&hash=item4170c0486a&vxp=mtr
I haven't even seen the manifold in person, and I'm still married, so you can assume I've never seen the carbs together with it. :) lol
jeremysdad
I was honestly considering a race-built C-4.
Idk...I think bracket racing in an N/A 4 cyl Pinto would be a ton of fun.
Thinking more into it, your suggestion would still be a good backup against a grenaded auto, as well.
I started down the same parts path with my street Pinto as you but instead found a complete low hour A.K. Miller draw through turbo set up. My son has had great success with his so I changed course and went turbo. I will also add for the twin carb set up, a good investment is an MSD "soft touch" chipped at 7000-7500 rpm. If you miss a shift, it will save the motor.
jeremysdad
It's going in the 'future project' tub for the present while I gather the other components. I couldn't pass it up.
I think a header will be my next acquisition, since they seem to be the hardest to find. Cams and carbs are easy (and as you mentioned, not cheap). :)
I am  considering getting the carbs new (300+ each) to avoid possible frustrations/wasting money on  possible crap used carbs.
You just bought yourself a financial can of worms. Rewarding if you can go the distance. Both 40s and 45s will work (45s may need to be choked down for the street). Carbs will set you back $400 +/- and you may still need to have them rebuilt $$$. Try to get the carb linkage with the carbs if possible as it is pricey. To maximize the set up, you will need a better than stock cam and a header. In my opinion, the rear end gears should be minimum of 3.73 but 4.11s are better to take advantage of the higher RPM. 7500RPM with 160HP is easy with this setup and it will definitely have the WOW value under the hood.
jeremysdad
Anybody got a pair of 40 DCOE's they don't need? lol
http://www.ebay.com/itm/111319812231
Start with mechanical...build the mechanical...understand the theories. :)
That's mine...I bought it...state-side. Now just need the side-drafts to go with it. :) lol
Well, they (2.0s) do love the revs...they really do!!! The racers won't steer you wrong. :)
